JazzVinyl
- Jan 7, 2010
And then a week or so after that I will start comparing the amps head to head.
Very much looking forward to the head to head amp shootout
Still going with my MK9 testing. Liked all of my DD headphones on it (Grado GH2's, Focal Elex's, Focal Elegia's, CFA Cascades and LSA HP-2's.
Started today by changing the amp to high gain and plugging in my T60 Argons. I am getting great volume at 1:00 (60 on the dial), but have to go to 2:00 (70 on the dial for older/softer music. To be specific, my ideal volume maxes in the low 70's, decible wise.
I thought I might be missing some punch, so I turned the Schiit Loki on. Of course I have to reduce the amp volume by 10 points to keep it comfortable.
Not sure about the Loki. I decided to go back to my test list and run through it twice, without and without the Loki engaged. Maybe even a third time with the stock drive tube? That is getting excessive, but...
Tung Sol BGRPTube rolling is now awesome. I have had several hybrids and this is my third "full" tube amp. I never really understood the religious zeal with which a lot of people swap tubes. I have found differences marginal at best.
Until now. You can make a night and day difference with drive tubes on this amp. Thick and bassy is lots of fun until it is too thick after a few days. Then another tube is fresh and clear until after a few days and it seems too bass light.
I can definitely see hunting for a tube that is bassy, yet open. You can probably go broke chasing this dragon.
I have to get back to that tube. As I recall it is in between the other two. I want to finish All the headphones and then start going amp vs amp. And then more tube rolling. I am dragging this out for months! No more snap decisions.i like your slow and deliberate approach to running the MK 9 through its paces.
i have noted the Arcturus (RCA) tube did not float your boat, so much?
There are some other tube brands that you should try.
Tung Sol and National Union immediately come to mind.
FTFY…[Reg. TM; © bcowen: 2021].Tube rolling is now awesome……..Youcanwillprobablygo broke chasing this dragon.
And what's your serial number out of curiosity?
Not that you asked me but, my new amp is Ser. # 922.And what's your serial number out of curiosity?
