Shane D
My amp definitely has some ventilation holes around the tube sockets, but it's not much. I have seen several hybrids with better ventilation. I am attaching a pic for an idea of how little it will ventilated.I think most amps have holes or slits for air convection, but it seems that in certain amps it is not enough to reduce the heat buildup inside the amp.
IMHO the main source of heat buildup in the amp comes from the tubes. Some tubes can reach 200-300C. By blowing air gently on the tubes (and the chassis) they are cooled down and transfer less heat to the chassis. In addition, I use a second fan that cools the transformer housing which usually is another source of heat.
Using fans and socket savers I can usually lower the overall temperature of the entire amp 10C.Since the amp is cooler, and because of a close correlation of the external and internal amp temperatures (maybe 3-5C hotter internally) this system is worthwhile.
Even in a closed amp without ventilation holes, lowering the amount of heat that enters the amp, helps to bring down the internal temperatures.
And regarding tubes, some tubes run much hotter than others as anybody who got burned by a 6080 tube can testify…
When the weather gets real hot here, July and August, can go longer) will be interesting.
Without the fan, the volume knob is very hot to touch. And right now it is 8 degrees outside (about 46 degrees Farenheit).
