Rossy007
- Feb 16, 2013
I just placed an order for -
NOS NIB Matched Pair Sylvania USA 6BE6 [5750] Gray Plate Vacuum Tube 6BE6 100%+
sorry, copied from ebay. I hope these are the right ones, thanks gibosi for your advice.
So tried to find what family these tubes belong to and all I could find was they possibly are EF92 and so as per the little dot guide, I followed the jumpers k1 & k2 to the side of 61j and j1 & j2 on. I must admit, I am having the worst luck with tubes. The first set,there was a buzz out of one of them and now these new ones I am having the same problem. Ignoring the buzzing, these are superb and give me exactly what I want in sound direct out from my CD player but the buzzing is making me regret getting this amp. Sorry...just frustrated
I'm looking to get a pair of Mullard 8161 tubes for my red dot and have a few questions. I searched ebay and found a pair, but the listing says CV4024. Is there a difference between that and CV401?
Also, I only skimmed through the first few pages of this thread and also looked at http://www.head-fi.org/t/563884/little-dot-tube-amps-vacuum-tube-rolling-guide#post_7625989 which both mention the Mullard 8161/CV401 to be the ideal tube... As you can probably notice both threads are pretty dated so I was wondering if anything has changed as far as another tube becoming more desirable.
Red Dot??? I assume you mean Little Dot?
Anyway, the CV4024 is not compatible with Little Dot amps. And I do not think you want a CV401 either. What I believe you want is either an M8161 or a CV4015. You might be able to find a CV131, but generally, CVXXX are older and not as good as CVXXXX. So I encourage you to search for the newer and better M8161, or even better yet, the CV4015.
I personally believe that the 6BE6 is a better sounding tube. The American premium version of the 6BE6 is the 5750. And if you would prefer the British CV version, that would be a CV4012.
Yeah, sorry I meant Little Dot (too much FPS games lol). I'm a little confused... If you look at the page I linked in my previous post you'll see "Mullard M8161/CV401". This makes me assume they are the same... forgive me as I'm new to all this. What confuses me is if I do a search for Mullard 8161 on ebay I get back results with different CVXXX variations, one of those being the CV4024 that I mentioned. So I'm a little confused as to what precisely I should be searching for... M8161 or CVXXXX?
The M8161 is the consumer version of this tube and the CV4015 is the British military version. The CV4015 is generally considered the best. However, it is my experience that military versions do not always sound better. However, they are more rugged and durable as these features are highly valued by the military. I have the CV4015, but not the M8161, so in this case, I just can't say.... Therefore, my best advice is to buy the CV4015 if you can find it at a good price. But if the CV4015 is too expensive, the M8161 for less money might very well be just as good. And it most certainly won't be bad.
Yes, these Sylvania 5750/6BE6 are definitely the right ones. And once you have had a chance to audition them, I hope you will let us know what you think.
Cheers!
