electropop
- Apr 23, 2008
Yeah. And even if something would in objective terms really sound better, you've gotten so used to the sound sig that it's almost impossible to change. You can call it 'falling in love'.
http://casque.generationmp3.com/wp-c...tle_dot_I_.jpg
You see the two switches on the left, nearest to the volume pot? It reads '408' and '6J1' between them. Those two set left means 6J1-family, both of them right means 408's.. That easy
If you want to use EF92's, you need to put in jumpers, which are included in the package, to the places 4 o'clock from the switches between the blue/red 'transistors/capasitors? (not sure). The thing in the middle, between the two small green round things, is the opamp. Just pull it out, put the lt1364 in and have a listen. The two bottom screws on both sides of the amp (total 4) are pretty quick to remove.. Just saying, that don't be afraid to try some different tube-families, since it's really easy! I hesitated at first too, but here we are
And I think the 6J1's and others in that family have been hogging the least praisal.. So just saying..
-K
-K
