gibosi
- Oct 18, 2012
I assume that it is only these new 6ZH1P-EV gold pin tubes that are problematic. That is, your other tubes sound fine. If so, then the problem would seem to be with these particular tubes.
First, if these tubes actually have gold pins, I find that to be suspicious. In my experience, 6ZH1P-EV have rhodium pins, so I wonder if the gold plating might have been done by a third party.... Ordinarily, given the symptoms you describe, I would suggest scraping and cleaning the pins to ensure that there is a good connection in the socket. But if they are gold plated, that really shouldn't be necessary. Otherwise, the best I can suggest is to allow them to burn in for 20 or so hours and see if they quiet down.
Good luck!
Good luck!
