harpo1
- Dec 1, 2014
Received mine today. Works perfectly with the LG V20 and FiiO M11.
Yes. The audio is passed through USB-C to the DAC/AMP/DSP in the lightning cable.
Any idea how this would work with a 2018 IPad Pro with a USB-C connection? Would I get the full functionality of the Cipher cable including DSP when using the Anker adapter?
That combo works well on my iPad Pro 12.9 2018 edition.
Whatever eq you have set on the cable will work on whatever device it's connected to. It's stored in the cableThank you! Just to clarify - the EQ that's built into the Cipher cable works on the iPad Pro with the Anker adapter?
Eq 1 is stored in the cable. The app allows for two. Used it on Razer phone USB c and a micro USB phone with an org cable.Can anyone confirm if you set the EQ on a IOS device, that it retains those settings when you plug it into the Anker on the Android device??
