- May 11, 2009
If your product is indeed superior to the competition and you can prove it, you would be silly not to bragg about it.
You're basically saying how superior your device is and bragging about it. It's like a cheap shot really.
Name one other audio company who calls out the competition (and a specific model in particular) for being not as good. I can't think of any at the top of my head.
http://www.audiophilleo.com/comparison.aspx
I see comparison matrices like these all the time
Pretty impressive the voltage output of more than 4V... IIRC, the USB maximum output is 5V, right?
I'm very curious to see it drives a pair of HE-500 sufficiently.
And what version did Gavin use? Regular, Super or Super Duper? I searched but couldn't find it.
Only the Super Duper was listed to have a 4 VRMS output rating. That was also missing from the test: which model they were using.
It's a pretty safe bet they were testing the Geek 1000 against the competition. It'll make their unit look better in testing and it's what their production partners are currently manufacturing so they'll have those on hand. I assumed from the start that they were testing the 1000. Whenever LH talks about the model in interviews they always seem to mention that 1W output spec and the price tag of the 450.
One more quick note that I think is important for non-techy people like myself— when we look at measurements that are measured in decibels (dB), every 3 dB difference is equivalent to a multiple of 2. For example, 5 dB is twice as loud as 2 dB. 8 dB is twice as loud as 5 dB and four times as loud as 2 dB.
At 1kHz, a 10dB gain correlates with a perceived doubling of loudness in some frequency ranges.
Ratio doubling means:
− a power level of +3 dB, or a sound intensity level of +3 dB
− an electric voltage level of +6 dB, or a sound pressure level of +6 dB
− a loudness level of about +10 dB
− 10 dB more SPL means 10 times increase in amplifier gain (amplification).
Doubling of the volume (loudness) should be felt as a level difference of 10 dB − acousticians say.
Doubling the sound pressure (voltage) corresponds to a measured level change of 6 dB.
Doubling of sound intensity (acoustic energy) belongs to a calculated level change of 3 dB.
I'm also curious as to why the Geek Out's two channels measurements are often out of balance with the bar graphs.
I am not sure what you mean by that....Could you clarify?
