m-i-c-k-e-y
The SOM has single and dual cpu variant.
The processor spec changed at least once during the campaign(s) and several times since. I am not concerned. What difference does it make whether it has one core or sixteen cores, was released six months ago or six years ago? As long as it does the job I don't see the difference, EXCEPT for "marketing value". Agai, as long as it does the job...
In the case of the Wave, this job is primarily to get the bits from storage to the DAC chip reliably and with as little jitter and noise as possible. The secondary tasks include the user interface and library management. There are also all the various hardware management tasks (storage, battery management, I/O, network, ....)
What is the concern with the type and number of processor cores? Is there a sound to processors? Is newer/faster/more cores by definition better? In what way? I trust that Larry and LH Labs has chosen the best processor for the task within the restrictions of the product physical, electrical and cost specs.
For those who are concerned about processors, RAM size, storage size, battery size, case material, appearance, design/development/delivery time, whatever... feel free to design your own DAP and bring it to market. Do tell us in detail how fast and easy it was to complete the projec, produce and deliver it and just how easy it was to design in absolute reliability.
Yes, I am tired of waiting. I first contributed to the Wave project April 9, 2014 and am certain that it will be over three years since then before I receive mine. This seems long since we have been following the project since its inception, but a three year development cycle is quite common. More than that can be expected for a first product - and the Wave is the first DAP that LH Labs has produced. You can consider this to be the most complex product that they have. It is a library/media server and high quality DAC all in one compact, battery powered portable unit. Just try to tell anyone that this is not a complicated project!
J.P.
Oh yes if LHL had focused on the Wave instead of all the other side projects.. server, headphones, etc.. maybe the Wave would have been delivered in a more timely fashion.. I worry that the Wave will be ho-hum compared to new players, when it is finally delivered.
