I have researched
FOUR Heat Dissipating possibilities for GEEK WAVE LH LABS in 30 minutes. Have they done their homework?????????????????????????? I am sure there is a better solution than they have at present. We backers can wait for a better solution rather than a cheap quick fix.
- This as I see it is the problem now for Geek Wave:
“most materials with good thermal conductivity conduct electricity as well. Vice versa, almost every electrical isolation material translates into a thermal barrier.”
So you need another material:
Ceramics, e.g. Rubalit (Al2O3) or Alunit (AlN), combine two crucial characteristics: they are
electrically isolating and thermally conductive.
Rubalit has a lower, Alunit a slightly higher conductivity than aluminium. On the other hand, Rubalit is less expensive than Alunit.
- Another product mentioned is Cerac (see quote below):
“Lighter, more compact, faster and more sophisticated
functions, are required of products in the field of electrical
and electronic devices in recent years. In order to respond
to such needs, further densification is taking place on
every level, including semiconductor chips, substrate
packaging and device mounting. Unfortunately, such
densification brought about an increase in heat generation
and the localized concentration of heat, which is causing
even more difficulty in terms of coping with heat.
Further, with the conversion of products into
household appliances and their personalization as well as
mobilization, demand for products with a better
appearance and less noise is on the rise. Very strict
limitations are being imposed on the designers, as they
deal with heat measures by hermetically sealing products,
quietening cooling fans or implementing heat measures
without cooling fans, in order to respond to such needs.
In such circumstances, there are cases when
conventional “heat conduction” heat dissipation products
(such as heat sinks) and “heat convection” heat
dissipation products (such as cooling fans) can no longer
offer any solution.
This paper will introduce the new innovative product,
“Stick-it Flexible” made of
Cerac α
Moving heat away from the transistor could allow for higher performance and reduce the need for cooling in any application where heat buildup is detrimental to product function (which is to say, most of them).
Boron has also earned scrutiny in recent years thanks to the way it partners up with graphene. As shown in the image at the top of the story, boron nitride and graphene can be grown side by side, creating nanowires of graphene that are isolated by the boron.
- Also see about the heat conductivity ir dissipating ability of CARBON FIBRE with nano tubes
“Thermal Conductivity of Carbon Fiber, and other Carbon Based Materials”
At http://www.christinedemer
