belgiangenius
- Sep 10, 2016
Bryston
BDA-3 (-)
In terms of the usual array of claims made for audiophile DACs, the Bryston BDA-3 is pretty basic. While Bryston talk up the sound quality, there’s little to call attention to in terms of the technology or engineering behind it.
A low noise power supply? Check.
Discrete, class-A, output stages? Check.
User-selectable up-sampling? Check.
Fancy clocks? Che … wait … what? No … none of that here, it seems.
Other than a wider than typical array of inputs, and the upsampling toggle, this is a pretty simple device, using a pair of AKM 4490s in mono-mode. This is a chip I generally find quite agreeable sonically, even if I feel it’s a bit out of place in a device at this price level – at least with with no other “special” treatments going on. After all, this chip now also features in Schiit’s $150 Modi 2 Uber.
Okay, there’s only one of them in Modi 2 Uber …
Maybe Schiit should offer monobloc DACS … you could buy about 20 of them for the price of the Bryston! Add a super-low-noise PSU (maybe the iFI 1uV wall-wart) and that would drive up the cost to the point where you could only buy 16 of them …
I digress …
Now, I’ll be the first to admit that the implementation of a DAC is at least as important as the choice of converter IC, and the results are really what matters regardless of other concerns, so we best get to that.
And, in short, I don’t feel this is in the same league as Yggdrasil at all. Sure it’s competent enough, with good detail, it’s quite dynamic, for the most part it’s transparent – though I did get a sense of a little bloom, or maybe blurring in the lower registers. At the opposite end of the spectrum there wasn’t a particularly vivid sense of air and brass seemed to lose a bit of its edge. Tone was generally good otherwise. PRaT was fine. But it lacked the ability to convey emotion and draw me into the music.
Presentation was very clean and not really analytical at all, and yet was less dry than would normally be the case for me to make those two statements, but again, it was lacking involvement for me. There was no sense of excitement, drama, passion, or any emotion at all listening to this thing and, at best, I could describe it as being vanilla. It’s not that it is bad by any means … it just isn’t that interesting to listen to.
This didn’t change with, or without, up-sampling engaged – though things got a bit smoother with up-sampling enabled.
The BDA-3 needs something else to make it interesting for me. I’m not sure what. A soul maybe. Or maybe something more reasonable … perhaps the ability to select from the DAC chip’s built in filter types. As it is, I don’t recall a filter setting called “forgettable” in the data-sheet. And I don’t know if that would help anyway.
So my impression here is that you have a perfectly competent, but not especially engaging or interesting, DAC, that, compared to the competition, is very hard to justify the $3,495 price tag for.
Gungnir would crucify this from a musicality and involvement perspective, and I mean the standard D/S version. Yggdrasil would make it carry the cross, dig the whole to erect it in, and then hand it the hammer and nails and make it bang them through its PCBs itself.
Perhaps this comes alive with DSD … I didn’t test that – I was done with my interest in DSD by that point. Or maybe it’s ability to take an HDMI feed from an SACD player is its saving grace. Didn’t try that either (I lack the necessary SACD player or discs). Otherwise, this just completely misses the mark for me.
Funny. Just based on pictures of the inside of this DAC, I fully expect your analysis to be accurate, Torq. (i.e., a fairly empty box)
Bryston is no doubt a big advertiser in Stereophile. The latest version of Stereophile goes on a tirade about how absolutely friggin awesome this DAC is. I believe the reviewer even called it the best DAC he's ever heard.
Some reviewers give points for functionality when they review. Personally, I couldn't care if a DAC anticipates the next big format, supports it before it exists, and offers 27 inputs to accommodate it.
If it doesn't sound the best, I ain't interested.
