LH Labs Geek Out v2+ Discussion Thread
Oct 17, 2016 at 8:28 PM Post #1,457 of 2,040
LH Labs mini b to b USB cable, that's what I bought for mine!
Did you get your cable through Indiegogo?  I finally got the Geekout, but am still waiting for the cable.
Oct 19, 2016 at 3:10 PM Post #1,459 of 2,040
LHLabs customer support sucks.
I received a unit with non working balanced output port and opened a ticket but no one reply. Its been 24hrs.
Sound coming from only 1 ear when i plug in the trrs plug into the balanced port.
Oct 19, 2016 at 3:17 PM Post #1,460 of 2,040
What type of headphone and cable are you using?
Oct 19, 2016 at 5:31 PM Post #1,462 of 2,040
I'm using a custom trrs cable by impactaudiocables, use with 64audio a12.
Sound can be coming from left or right ear but not both.
I've heard of issues with TRRS when the pin-out doesn't align correctly. Here's the pattern for the GOV2.
Unfortunately there's not a set pattern for wiring TRRS connections. Here's AK's
Might want to double-check the way the cable was made. Good luck!
Oct 20, 2016 at 12:15 PM Post #1,465 of 2,040
hmmmm you temp me!!!
Oct 20, 2016 at 1:42 PM Post #1,466 of 2,040
It is a nice piece of gear! Have one myself and it's really close in SQ to the Pulse Inf. Cheers
Oct 20, 2016 at 1:54 PM Post #1,467 of 2,040
I sent the cable back to impactaudiocables for inspection and it was nothing wrong with the cable.
The issue must the with go v2+ then.
Oct 21, 2016 at 10:20 AM Post #1,468 of 2,040
This is my first time dealing with LHLabs and it will be the last time. Customer service sucks big time. There is no way to contact them except to open a ticket.
I opened a ticket for rma to repair yesterday and today it got closed without resolve my issue.
Oct 21, 2016 at 4:00 PM Post #1,469 of 2,040
I received my GOV2+∞ the other day and have been giving it a bit of a workout. I've run it through 2 complete power cycles and it takes approximately 5 hours to fully charge. Is anyone else experiencing these long charge times ? The 2nd time I used a LH Labs 1G USB A to Micro B cable and a good 2A charger. Generally I can charge a 2800mah battery in 1hr 40mins with that charging set up.
I understood the power light indicator would turn red before shutting down, I never noticed I noticed a red light either time (wasn't waiting for it, but never noticed) and the unit simply powered down. The second time it was connected to a PC workstation using JRiver and when it powered off it locked out the Task Bar in Windows 10 - had to reboot the PC. Seems strange. Otherwise performance on PC's with Win 10 as system audio worked seamlessly (also used Surface Pro 3 with JRiver).
My main interest is Android audio - portable HiFi. I'm struggling with this. My Fiio E18 uses a different type of B2B OTG cable which (won't work with GOV2+) once connected, Android recognizes the USB DAC and operates as system level audio device. OTOH, the GOV2+ can only work with certain apps ? Like UAPP & HibyMusic and not as a system level audio device?  That seems lame!
I've been able to trick GOV2+ to playback from Google Play/Tune In/YouTube and system sounds from my phone - but something is off with the SQ and it lights up the 4x LED on the GOV2+.
I'm assuming that this has to do with limitations of Android USB Audio standards for hi bit rate files, but why not do both?
My android devices include OnePlus One & OnePlus X, both with Sultan's CM13 ROM, and Nexus 9 stock.
Oct 21, 2016 at 4:14 PM Post #1,470 of 2,040
The support is definitely lacking. However, all may not be lost. I got a similar experience asking for the latest firmware. After I answered all their question, they closed the ticket without sending me the firmware. 4 days later, they emailed the firmware to me. I would not be surprised that you get an RMA shipping label in a few days.
