wildforest
does all v30 versions comes with quad dac?
yesdoes all v30 versions comes with quad dac?
please can you explain more?yes
I recently looked at the score sn 835
and came to the conclusion that I would try something on 888 + type c dac
I have been using v30 for a long timeplease can you explain more?
I bought 1battery from ifixtit. And thr adhesive from aliexpress.Has anyone done a Battery Replacement for their V30? I'm bringing my V30 back to life and was wondering what's the Best Replacement Battery options available. Prefer one from Amazon, I saw one for 3800mAh.
I'm a bit skeptical with 3rd party batteries, don't want it to explode // catch fire.
Wow I would like to know also.Are these in China legit ?
if you didn't have any LG before, it is recommended, i am happy with lg v30, still keeping as backup, but now my daily driver is LG v50, cause i am waiting for 5G madly1. is there sense getting v30 to be used with budget iem-s like soundmagic e11 or sennheiser hd 569 headphones? my music is flac / wav 44 16
2. is v30 good choice for warm reproduction (i`m listening mostly edm - progressive house, deep house) because what i can read here is that v30 is on the bright side? or i can easily make it warmer by using eq and filters and some specific headphones?
besides this, there is one thing on v30 that is really frustrating for me - mono speaker. even worse - it`s not face directed but down. this is so wrong that it cannot be more wrong. i`m often watching some youtube podcast or some kind of video that is not so important about audio quality so i`m listening it without headphones. and to have this down faced mono speaker is so wrong. not surprised lg disappeared from the smartphone scene with this kind of design.
Woohooo got it from taobao. Now i can play CODm with it
How did you get the back plate of your V30 off? I bought a replacement battery and DIY tools; however even after heating the backplate, the suction pad still wouldn't remove it. Thinking I will have to get a repair specialist to do it as I don't want to break my V30.I bought 1battery from ifixtit. And thr adhesive from aliexpress.
Need to heat it up more and use the prying tool.How did you get the back plate of your V30 off? I bought a replacement battery and DIY tools; however even after heating the backplate, the suction pad still wouldn't remove it. Thinking I will have to get a repair specialist to do it as I don't want to break my V30.
It has 75 volume steps and that’s set in stone.Does anyone happen to know if the V30 's Volume can be MAX out at 100? mine caps out at 75. I have the V30 hook up to an external Volume controller for Desktop listening.
