odontonator
I never use impedance adapters etc.. if I want to go to aux mode which would be the next mode up from hi-fi mode I always plug the cable to the phone first and attach the iem/hp to the cable second. Keep in mind this is not giving you better sound quality it is merely giving you more power to drive your gear.
Do you use the aux mode or trick the V30 into hi-impedance mode to drive your Aeon Flow Open HPs? I just ordered these after reading all the reviews on Head-Fi and elsewhere. I auditioned both the HD800s and LCD-X in the store with my V30 and really enjoyed the signature of the LCD-X once in hi-impedance mode. From what I've read, the AFO would seem to improve upon what I like about the LCD-X, but also have the same liability in needing to trick the V30 to supply more power. In the store I just used my old HD570s attached to the extension to trip the V30 into hi-impedance and may just do this while at home, which is where I'll be listening to the AFOs. I'm currently listening via my Shure se846s and will continue to while mobile or at work.
