gr8soundz
- Jun 28, 2014
PA: Okay, we used a pair of Audio Technica ATH-M50x studio monitors and played a bunch of lossless FLAC tracks on the HTC 10, the LG V20, and the LG V10. No surprises - the sound from all three came clear, dynamic, and generally quite pleasing. However, if you're like your music really loud, then the HTC 10 will win you over — this one is way louder than either the LG V20 or the V10, almost to the point of physically hurting your ears. That aside, we can't say we could distinguish a stark quality difference between the three as they all performed excellently in terms of hi-fi audio playback.
PA: While the LG V20 is a rather capable hi-fi device. It will, however, impress you way more if you have a pair of high-impedance headphones and listen to lossless audio tracks. While the HTC 10 is a bit louder, both devices are pretty similar in terms of audio reproduction. For casual listening to music, like streaming Spotify or Google Play Music while on the go, the V20 is in the same ballpark as any other high-end device.
The M50x are 38 ohms so they were probably getting only normal power with them on the V20.
I'm not doubting their results, but I've come to ignore most opinions about V series audio unless the person specifies which power mode they were actually in (assuming they even know the V10 and V20 have variable output levels).
