LG V20 Sound Quality
post-15156305
Post #3,916 of 4,025
Starfinder
UK
UK
where did you order from please, I can't find any
post-15156345
Post #3,918 of 4,025
Starfinder
UK
UK
post-15156349
Post #3,919 of 4,025
m-i-c-k-e-y
The Eternal City
The Eternal City
post-15156368
Post #3,920 of 4,025
Starfinder
UK
UK
thanks ordered
post-15167071
Post #3,921 of 4,025
henrylar
I have an idea, it might be hot garbage but...
I read to trick the V20 into high impedance mode a +50ohms resistor is required on the right channel. So I took my current IEMs cable, a 3.5mm to 2pin, and bridged the 2pin end with the jack pins on a pair of high impendence (60ohms) headphones I own then plugged the 3.5mm end it into the V20 and success, high impedance mode activated.
My follow up idea is to get a female mmcx socket and solder in a +50ohms resistor, then when I get the Tin Hifi P1 IEMS I will remove the right IEM, replace with the female mmcx resistor I made, insert 3.5mm end into the v20, then swap the right side P1 back on the cable.
If successfully the advantages of this method I see are as follows.
Cheaper
higher quality as no patch cable is needed
less to carry around.
I imagine on a 2pin cable, you might only need to use tiny resistor itself, just bridge the pins on the right channel when inserting the cable, then plug in the iem/headphones in
I'm a newbie so everything I said could be wrong, this is why I humbly submit this idea for the scrutiny of the head-fi hive mind.
thanks[/QUOTE
The key is to make a female plug for the right plug that goes to the headphone. Solder a 60 -100 ohm resistor across the plug. Plug in the wire into the phone, unplug your female plug with the resistor and plug in the headphone.
I have the Oppo PM3, which have an ordinary jack in the headphone end, which makes it easy to make a female plug. Works fine. Alternatively you can just plug in the wire without the headphone and you will get a medium power amplifier. Quite simple.
post-15173015
Post #3,922 of 4,025
Dartin Bout
I'm in the UK, I'm a bit concerned that the ones on aliexpress look fake, the only other option I can find has a questionable site, has anyone had experience with either and can confirm its legit?
http://www.perfineshop.com/product/image-processing.html
https://www.aliexpress.com/i/32957219050.html
I've had this audio dynamo for 3 years, come October. I must have gone through a dozen different batterie,s from all sorts of sources, Amazon, Aliexpress and a site in Singapore where I pad $35 for the 1st of the Li-Po's (they are now much cheaper). I always carry a spare. They all worked. I'm really hard on batteries as I listen to music all day, when I'm away from home, Wired, bluetooth and couple of external DAC's, All the batteries seem to last about a year before they poop out except for the Perfine 6600's. I just ordered 2 4500 Li-Po's from Aliexpress and a new slim back cover that is supposed to provide better cooling. Streaming MLB games really heats the sucker up. This is the 1st phone I've ever had longer then a year primarily because of the DAC and the replaceable battery. I blast it on full brightness, volume turned to "11", LDAC set to high quality. As they said on the 1st battery I got, "Life is Good", I would add that "Music is Life" and this phone(?) is the best portable tech I'll ever likely own.
Reactions: ezzony and Hooster
post-15173147
Post #3,923 of 4,025
LightBlue77
Iasi, Romania
Iasi, Romania
I've had v30, fiio x5iii, now i own a pioneer xdp-300r which is better but still i get happy listening hours with v20. I am still amazed how good hifiman re2000 sound with it. The portability of a phone with good dac is really joyful.
post-15222845
Post #3,924 of 4,025
Malefoda
Hi guys,
as I wanted a DAP for my daily 2 hours bus and needed to upgrade from my Nokia 3210 (yes, I am using it :) ), I've seen a LG V20 as a great cheap used alternative. It's working fine, done the tricks OEM music player/enable 16/44.1 on a rooted former AT&T V20. First, I find the ESS DAC enable is a very light improvement, no way to hear the SQ gain in the bus but only in quiet listening with good headphones.
Now is my question, as always it's a chain so links must "match" sonically to give the best. I find my Alessandro MS-1 (MS-1000 mod) to be a tad bright with the V20, but it's OK to me I can cope with it. Now I've bought 30USD JVC HA-S500 and it's so muddy bassy unclear with added boost to cymbals I don't like it. I wonder if some Koss KSC75 (which I owned long time ago and remember to be good and far less muddy) are a good pick, said in an other way any know great match for the V20 you can recommend under 50USD?
Thanks!
post-15222936
Post #3,925 of 4,025
Starfinder
UK
UK
KSC75 is great with the v20. For better fit and soundstage, I use mine with the headband mod and yaxipads.
But on a bus I would personally go with an IEM to isolate the sound of the bus out and the music in. I'm digging the KZ ZSX at the moment but have Blon BL03 is arriving soon.
post-15223765
Post #3,927 of 4,025
m-i-c-k-e-y
The Eternal City
The Eternal City
What they said. The IEM route.
Not bulky and isolates you with the noise around.
post-15223927
Post #3,928 of 4,025
Starfinder
UK
UK
post-15224026
Post #3,929 of 4,025
Malefoda
Thanks guys,
but sadly I can't stand IEMs :frowning2:
May buy the KSC75 as a quick replacement.
post-15228514
Post #3,930 of 4,025
ezzony
Mayo, Ireland
Mayo, Ireland
I realize you prolly got your battery by now but for anyone else those links are the one's I bought and they are genuine. I'm personally delighted with them, I've never had a phone that had lasted so long on a charge ever. Only downside for me is that it took a good month to be delivered to Ireland, but what can you do, the world is big.
Reactions: Roll
