LG V20 Sound Quality
Mar 23, 2018 at 1:55 PM Post #3,514 of 4,149
I own the ZX2 as well, and I'm beginning to feel it was a waste of money, considering I got the v20 new for $330 aud. Ah well, that's life.
Lg V20 cannot touch the ZX2 once you use TRRS,disable sound adjustment and listen to a really detailed iem.The sound is not as nuanced,detailed or layered.Instruments,particularly guitar strings do no sound as realistic and meaty like ZX2,it's more lean sounding and transparency is not up to a high end dap but for a phone it is really impressive.I very much like it with modded se535 and can even drive HD660S adequately but no where near as good as mojo.
Using it as a source for mojo though is a disappointment..
Mar 26, 2018 at 3:10 PM Post #3,515 of 4,149
I'm using Neutron which I preferred over PowerAmp in a side by side. I haven't really experimented a ton with UAPP.
Ironically enough Neutron into my GO v2+ is how I run my LG v20 when I want to listen!
Mar 26, 2018 at 3:13 PM Post #3,516 of 4,149
With the current major update of UAPP (using its Hires Driver) we can now acess directly the DAC bypassing Android. Big props to the developer.
Mar 29, 2018 at 11:02 PM Post #3,518 of 4,149
+1
It's very similar to properly configured Neutron player. These 2 are pretty much the best options currently.
Agreed. I have actually dropped Neutron in favour of the new & vastly improved UAPP. It has breathed new life into the spectacular 2+ year old V20. I decided to buy the V20 a month ago over the V30 because it was a third of the price and same "quad dac". This just makes it all that much better of a decision.
Apr 11, 2018 at 10:36 PM Post #3,520 of 4,149
Is there any portable dac at a budget range that i can stack with my v20 to get an improvement? Using Flc 8s.
Perhaps Dragonfly Red, or Black if you're really on a budget. Red has the edge audio and power-wise but Black I find better on battery charge life.
Apr 11, 2018 at 10:46 PM Post #3,521 of 4,149
First have you tried tricking your V20 into high impedance mode? I would try that first. Many feel that this significantly improves the sound of the V20.
It's just that I doubt that either of the Dragonfly's will produce any improvement over the V20 itself as they both use very similar if not identical ESS DAC's and amps.
Apr 11, 2018 at 10:53 PM Post #3,523 of 4,149
Won't high impedance mode damage my iem of 11ohms?
High Impedance mode in and of itself should not damage your IEM's. You will just have to excersize caution with the volume control. Now I don't know but it's possible that with very sensitive IEM's and the combination of high impedance mode there could be some hiss at normal listening levels.
