I tried to reply your test with RMAA, as explained here
https://www.head-fi.org/threads/the...urements-in-post-3-tutorial-in-post-2.800208/
with the mobile loaded with sennheiser ie80 (small load)
Guess what, same result as you with all players, i.e.roll-off beyond 18kHz. I would say that this falls beyond audible frequencies.
One notable exception: aimp (audiotrack method) rolls off way before 18 kHz, and shows better stereo crosstalk values, compared to the other players.
I guess what we are seeing here is some software tuning.
I also tried a test for the V20 with higher demanding heaphones and a 75 ohm impedance adapter in the measurement loop.
Same frequency response as with stock player.
There where signs of amplifier suffering (high distorsion), but with better crosstalk values.
I guess this is a hint the V20 is optimized for high impedance, high efficiency headphones.
Interesting thing 1: the only value seriously affected when switching the dac off was stereo crosstalk, which probably means that really the V20 makes a difference for high impedance loads.
Interesting thing 2: I compared the results with my old lumia 820, using foobar for windows phone. The test shows a marked roll-off similar to aimp for the V20, but if the wasapi option is chosen the rolloff frequency increase, as in the other players for the V20.
Conclusions:
1- the DAC - software interface problems are more common than we think
2- still not sure this HF rolloff at 18 +kHz is audible
3- the roll-off for Win phone foobar without wasapi is clearly audible
4- I definitely would like some feedback from the more expert members of this community
5- probably the V20 is best performing with high impedance, high efficiency headphones.
I will reply to myself because I have some serious updates.
I repeated the tests with RMAA test audio file encoded first in opus.ogg (160 kbps) and then in .mp3 (320 kbps), for both my LG V20 and the old Lumia 820.
The overall readings degrades, especially the ones connected to the stereo tests.
The frequency response instead becomes completely flat!!!
For the V20 this happens with all music player except AIMP, which when playing the mp3 still gently roll-off the highs gradually, starting from 10 kHz.
One exception: Rocket player reading are overall worse, which leads me to believe it just does not use the DAC.
It is also interesting that thanks to the degradation coming from the compressed files, the measurements of the Lumia are on par. with the ones of the V20.
What does it means? Is it only RMAA black magic, or really any mobile is just good enough to play compressed audio file on easy to drive IEMS like the IE80?
I will post soon my measurement hoping for somebody to shed some light on this mystery.
