I created a pink noise 24/96 FLAC, and loaded it on my phone. Then I played it back, and analyzed it with a SB 24/96 card, and TrueRTA 24oct.
The Fiio X5iii, the Galaxy S8+ and the LG V10 hit 48 KHz with ease.
The LG V20 dropped off like a rock from 18 KHz onwards, no matter what I did, and no matter what player I used.
I tried to reply your test with RMAA, as explained here
https://www.head-fi.org/threads/the...urements-in-post-3-tutorial-in-post-2.800208/
with the mobile loaded with sennheiser ie80 (small load)
Guess what, same result as you with all players, i.e.roll-off beyond 18kHz. I would say that this falls beyond audible frequencies.
One notable exception: aimp (audiotrack method) rolls off way before 18 kHz, and shows better stereo crosstalk values, compared to the other players.
I guess what we are seeing here is some software tuning.
I also tried a test for the V20 with higher demanding heaphones and a 75 ohm impedance adapter in the measurement loop.
Same frequency response as with stock player.
There where signs of amplifier suffering (high distorsion), but with better crosstalk values.
I guess this is a hint the V20 is optimized for high impedance, high efficiency headphones.
Interesting thing 1: the only value seriously affected when switching the dac off was stereo crosstalk, which probably means that really the V20 makes a difference for high impedance loads.
Interesting thing 2: I compared the results with my old lumia 820, using foobar for windows phone. The test shows a marked roll-off similar to aimp for the V20, but if the wasapi option is chosen the rolloff frequency increase, as in the other players for the V20.
Conclusions:
1- the DAC - software interface problems are more common than we think
2- still not sure this HF rolloff at 18 +kHz is audible
3- the roll-off for Win phone foobar without wasapi is clearly audible
4- I definitely would like some feedback from the more expert members of this community
5- probably the V20 is best performing with high impedance, high efficiency headphones.
