Zildon
Hello. Did you properly diagnose that UAAP was the culprit ? (is it shown in battery status as the one eating the battery ?) Did you try to erase all data and cache (from settings/apps/UAAP) from UAAP ? You could also back up the phone, factory reset, reinstall just UAAP and see if the problem is still there... If not, reinstall apps one by one to see if there's a conflict somewhere.
Did you root the device ? Did you change the kernel or something else ? Did you change something in UAAP settings ?
By the way, you could try to contact the UAAP developer(s) if everything fails, they seem to be quite supportive. You should also post on xda forums (or did you already ?) for such issues.
Hi, thanks for your quick reply. I have checked the the battery stats each time and UAPP shows more percentage than the screen or android system. Thanks for you suggestions about factory resetting and uninstalling and reinstalling all my apps one by one. That would certainly show if UAPP was in conflict with another programme. However, this would take so much time to affect for an app that I am unsure sounds any better than the LG stock app when using the internal quad dacs like I do with this phone. Just was wondering if anyone else experienced the same heat/ battery drain issues. Have uninstalled UAPP now and alternating between LG stock app, poweramp alpha, and player pro; still cant make my mind up!
