vwinter
- Oct 6, 2010
It doesn't mask or really warm up the midrange too much.
Inks seems to have a higher opinion of them than you do, so I would expect him to have a degree of motivation.
Do we need a seperate thread for QB2 SE? It is already available at e-bay:
http://www.ebay.com/itm/LG-HSS-F531-B-earphones-QuadBeat2-Special-Edition-Earset-For-Smartphone-Black-/221334899168?pt=US_Headphones&hash=item33889689e0
I am sure I will be ordering them soon, but a comparison would be more tempting for us.
Had the quadbeats 2 for a week now as it came with my LG G2. After reading this thread, I gave it a shot and used it instead of spending another hundred bucks for an IEM (c'mon ~$650 is hard on the wallet). I must say this is surprisingly solid. The low end seems to be a bit bloated but I'm not complaining. Midrange is solid though I find guitars a bit honky at times. Highs were surprisingly good. Crisp and has ample amount of shimmer and energy to make my happy. I wasn't expecting much from a smartphone-bundled IEM but QB2 exceeded my expectations. They are solid and probably keep me satisfied for a while as my IEM for commuting.
A bit OT. They sound better from my iPhone 4 than my LG G2. Same files and all. Hmm.
Anandtech did a smartphone sound quality analysis. The G2 introduces 5%+ THD at max volume, while the iPhone does not. See if you can use a USB DAC.
So what? The Quadbeat 2s shouldn't need anything approaching max volume coming out of the G2 unless you desperately need to destroy your hearing.
Saying "get a USB DAC" is pointless for this "problem".
Unless you actually needed to use max volume, like on the Nexus 5 which shares a similar chipset... so it is very much relevant and not pointless at all.
I'm not refuting the data. I'm saying it's irrelevant. We're talking about issues that exist at, or very near, maximum output volume. Unless you're using headphones with substantial impedance (or, again, you desperately wish to permanently damage your hearing) it will never be an issue. This is true for not only the Quadbeat 2 but literally hundreds of other models of headphones on the market.
Stop introducing variables that simply don't exist in this situation.
