- Mar 6, 2014
Used mine with several dac/amps at canjam without issue, I was running a PAC rom at the time.
The G3 just came to Boost Mobile. Anyone have any experiences with it?
depending on what your gonna use them with and your listening habits. It has pretty good SQ, good enough for on the go, but volume output is kind of low. They work good with iems, but headphones are depending on how loud you listen to music and which headphone you use. It does its job and if you want, you can add a amp/dac later.
well I ask because Ive seen phones that come from premium contract carriers to cheaper prepaid carriers a year or two later have different specs (cheaper) than the original. I plan on using the M4U1 and T70p. I prefer listening right from the headphone jack but I do have a FiiO E18 dac/amp. Did I read somewhere that the G3 supports 192khz audio? or am I just dreaming?
By the way, to anyone interested..... I previously raised a concern of using the E18 with the G3.my concern was that, when using the E18 as a DAC, I was still able to adjust the volume from the phone. To me this suggested that the audio was still being processed by the phone instead of being bypassed.
I think I may just have confirmed this to be true. Earlier tonight I installed Hibymusic (music app) and what do you know..? A message popped up asking me if I want to allow Hibymusic to access the USB device. Now, I can't adjust the volume from the phone, only from the E18,which suggests that there is no audio processing being done by the phone anymore.
I prefer the UI of the stock music player, but Hibymusic is still quite clean... Clean enough that I'll stick with it. I also tried Poweramp and Shuttle, but neither of them did the bypassing.
Interesting. I've always used USB Player Pro, which also ask to use the E18 when its connected. I remember music playing even when the phone volume is mute, but I'll double check later. How does the E18 fair when used in amp only mode with the G3?
im running stock rom, but rooted.
What variant are do you have? Im on verizon, v985
IIRC when rooting you'll have to reinstall everything, so if you have a treasured memory or otherwise that you need to get back, I do not believe rooting will be your answer.
Are you sure rooting wipes out everything on your phone? I have seen video tutorials with the one click root solution where everything is intact. I am going to copy everything to a hard drive anyway with a program I found which keeps all the photos attributes, a program I wish I found earlier
