fran
- May 3, 2006
This stuff has me thinking a bit.....
The main difference between the LD2 and LD2+ was a) different pre tubes, and b) the preamp capability. I and many others have the LD2 and haven't seen the arcing problem, never saw it mentioned even once in relation to LD2, although it uses the same 4P1S tubes. So I wonder are these tubes being "overdriven" to allow use as a preamp? I wonder could a persons LD2+ be stepped back to a LD2 and avoid this problem (assuming you wouldn't miss the preamp capability and that you had enough interest to do it)?
Also, before I got my LD2, I watched for ages the reactions. The LD2 went through 4 versions until its where its at now, using different tubes, 1b2, 1k2 AFAIK, different capacitors and so on. It seems that to my eyes this V4 has been pretty reliable.... 2nd hand buyers take note! I wonder if this will be the same story with the LD2+, ie go through a few versions until it settles down...
Fran
Fran
