colinharding
- Jun 29, 2008
Perfect thank you! And henceforth it shall be called amplification stage in my references ![Wink :wink: :wink:](https://cdn.head-fi.org/e/people/wink.svg)
I tested last night, compared to the output of my Soekris 1421 the very top end was not as sparkly, not much of a difference but something I picked up on. May just be the 6H13C tube though.. the GE 6AS7GA is sounding almost identical to the DAC output!The specimen I tested has flat response (-0.1dB) from 22Hz to about 46KHz ref. 1kHz, at 8V into 300 Ohm (almost full power). I don't see that the top end is restricted. Different tube combinations may have different distortion profiles which affect the perceived FR flatness, though. A lower load resistor will result in better top end response at a cost of slightly increased distortion, but given the decent performance of the original circuit, the improvement might not be discernible.
Vt-116. Also not sure why tapping stops the hum![]()
I guess the base could cause the issue. Not seen that one before unless it's also somehow moving some of the internals when it moves.
Think I'd just get another tube if I were you. The JAN 6SJ7 are quite cheap. The 'red hot' version of this also sounds quite a bit better, may be worth just moving in that direction.
Both works quite well with the GEC CV 4079, in a different way.Ha gotcha - had thought these were the metal encased versions of the tube.
Makes a bit more sense as to the humming and loose base now. Apologies for my initial confusion. Have you tried these tubes against the mesh Tung Sol version by chance?
