simmconn
- Dec 19, 2008
Does anyone know if it's possible to make the 339i work with 6sn7 tubes?
So you are not happy with my answer?
Ngl I forgot lol. But I guess I'm looking for a way to get around the heater issue.So you are not happy with my answer?
I'll give it a try. Sounds like if somethings goin bad it shouldn't be too hard to notice?I'd just go for it. The added heater current is 0.3A, which is only about 10% of the nominal for a 6080 plus a 6SJ7. It's not going to set your amp in fire. Besides, the heater voltage from the trans is too high to begin with. Adding a bit more load helps taming it down a little bit.
Looks nice! From whom You need to protect the tubes?Fun never ends! I painted the tube shield in black but I was dismayed by my crafting in general, so one day when I was buying stationary in Target and found this pencil box. Works perfectly!
Good question, i have had no idea there are 7623)I am using Philips (Mullard) 6080 tubes now. What is the difference between the 6080 and 7623 tubes? They look very similar
Does any metal work?
It is called a Faraday cage and anything metal will do. (Obviously audiophile grade gold plated unobtanium will work the best - This is a joke)).Does any metal work?
I was just gonna use some like , copper mesh like you use for rats lolIt is called a Faraday cage and anything metal will do. (Obviously audiophile grade gold plated unobtanium will work the best - This is a joke)).
As far as I know a top cover is not needed but based on my expirements the results are better if you ground the enclosure to an exposed metal point on the chassis of the amp.
Being frugal I found a no cost solution - took an old window metal mesh screen and cut out a piece and folded it into a rectangle. Used two binder clips to keep it together and an alligator clip lead for ground.
It did help for hum from the tubes but with certain tubes I could not eliminate it completely. Still, using the cage, the hum was lowered and playing music mostly masked the hum. YMMV
You can cut the mesh to size for your amp and I am sure that there are more elegant methods to keep it together etc, but this is just to show the concept.
Have fun!
