La Figaro 339
Sep 27, 2014 at 4:48 PM Post #2,418 of 6,903
Thanks Yuking, I wish I had a HD800 to testify! And yes L63 tubes are meant for the modded 339, not the default one.
Sep 27, 2014 at 8:47 PM Post #2,419 of 6,903
I am looking at the 339 very nice looking amp i see very popular with Senns HD650 and HE 500 HP but what is the consensus regarding the Senns HD800 i saw a couple negative comments are they recommended with this amp was reading that this amp is very neutral and SS like .i use my Senns with a WA2 and a Burson Conductor i also have a pair Denon's d-5000 anybody ever gave a listen with these HP. Appreciate your comments .
Sep 27, 2014 at 9:47 PM Post #2,421 of 6,903
To both of the above comments, I am using RCA 6080 + NOS 6J4P.
It's fantastic with the HD800 - the best amp I've heard for the HD800 thus far.
It rolls the treble just lightly enough to give a full bodied feel to the 800.
Sep 29, 2014 at 3:00 PM Post #2,422 of 6,903
DELETED
Sep 29, 2014 at 3:05 PM Post #2,423 of 6,903
What are the good tubes for a unmodded 2013 revision stock 339 .Are the RCA 5693 reds part of those  Thanks
Sep 29, 2014 at 10:20 PM Post #2,426 of 6,903
  Do you guys get humming from this amp?
I do - is this a result of the amp, or the tubes?
It's not annoying by any means. Just occasionally noticeable.
Who knows it might be tubes i use to get a hum on another amp and it was the tube and eventually it almost went away best thing is to interchange tubes does it come from one side in particular or just try another set.
