Paul Staples
- Mar 29, 2017
what is ground box?Just wonder if anyone tried connecting ground box to the dac?
I used the ART cleanbox2 on my electrical wirings but not connecting to the dac. I used it in between my av receiver and the amplifier with the intention to eliminate any hum noises from power strip cables . For the dac, I prefer direct pure silver cable to the amplifier.Just wonder if anyone tried connecting ground box to the dac?
No. Had not tried that. Sounds like a wooden box with some magic soil inside. Pretty expensive to get one and try it out. I'm thinking the whole thing is about connecting the audio equipment to earth right? I might try a DIY on this. Get a wooden box. Go to the garden, get some soil to fill it up. Punch a few nails into the box. Use speaker cables to clamp outputs from DAC to the nails.I am talking about this
Fill the box with corpse and bone, and the dirt from a graveyard. It sounds better that wayNo. Had not tried that. Sounds like a wooden box with some magic soil inside. Pretty expensive to get one and try it out. I'm thinking the whole thing is about connecting the audio equipment to earth right? I might try a DIY on this. Get a wooden box. Go to the garden, get some soil to fill it up. Punch a few nails into the box. Use speaker cables to clamp outputs from DAC to the nails.
Yes. That will make it dead quietFill the box with corpse and bone, and the dirt from a graveyard. It sounds better that way
You can actually use Jriver library management and HQplayer for playback. Check out https://www.computeraudiophile.com/...r-to-hqplayer-a-very-limited-solution/?page=8. Works for me, not a bad option if you like HQPlayer playback but not its ui or library management (and you dont want to pay for Roon as well). Somehow, I never get that excited about HQPlayer even though technically it should be lot better than jriver.Woa, trying out HQPlayer! Thanks @littlexx26 for the configuration picture. I am playing it back now. Awesome ! Different filters do different things ! Crazily awesome.
My favorite now is Poly Sinc Shrt mp 2s
Now I need to figure out this library thing X_X
There are no dip switches on the LKS004. Some external usb/i2s bridges like the Singxer SU-1 will have dip switches.I was curious... if you're not using i2s connection with dac, do you need to worry about dip switches position?
