OK there's must be some type of confusion here because you're way too smart to believe this : ) What I get from that bolded sentence is that you don't believe silver can be drawn, forget casting for now lol. Please tell me this is not what you meant.
What did you send me? That was a link on how to extract silver from silver ore
Honestly, I would've just left this alone if it was someone who I didn't think it really mattered if they knew the truth or not. But we can't have you going through your life not believing in OCC silver : ) You've taught me a lot following your build and I feel I should reciprocate something back.
Firstly, and forgive me if you already are privy to any of this, there are other ways to get a metal free from grain-boundaries. A company like AudioQuest purchases drawn copper and silver then polishes the grainy texture off the cable either in a one or two step process, instead of purchasing OCC metals. Both processes are trying to replicate the very same thing, a cable surface free of boundaries allowing for uninterrupted signal flow.
Secondly, I'll also mention that the purity of the metal always meant more to my ears then whether it's OCC or not. Cardas is a great example. They are only one of two cable companies in the world that draw their own copper in house. Cardas actually sells it's copper to dozens of cable manufacturers, with AQ and Kimber being only two of the notables. Nordost is the other cable company drawing their own copper (they silver-plate). Point is, neither of these massive cables companies - possibly the two with the biggest reach in the world - neither of them use OCC. Purity, draw speed and die quality, polishing and construction is what makes a cable, but OCC has it's purpose if you start with very pure metal. Namely polishing 24-28awg wire evenly and consistently is an expensive process. More expensive then just purchasing OCC metals from one of the three manufacturers in the world.
Onto the silver OCC myth. There's some very well credentialed links at the bottom if you'd like to peruse.
This gentleman with an undergraduate degree in Chemical Engineering with specialty in Metallurgy and a Master’s degree in Mechanical Engineering in robotics, runs a very successful cable company out of Toronto and his father worked on his Ph. D. degree in Chemical Engineering at U of T at the same time as Dr. Ohno in the early sixties and they went on to become lifelong friends ever since. Btw I'm good friends with this gentleman and have been shown mulitple photos from multiple years of his father and Dr. Ohno together. So the story definitely checks out.
Please have a look at his thoughts on OCC. I'm sorry but until anyone speaks with folks as close to the OCC process as Steven has, and continues to this day, no one should be allowed to argue against the point when he stats that, "Ohno Continuous Casting...can be used with a wide variety of metals including copper, silver, aluminum, tin, bismuth, and others." He uses both OCC copper and silver in his cables and would basically tell you, who are you to claim his silver isn't OCC? He may be an a**hole about it now, but he's a correct a**hole : )
https://www.dagogo.com/an-interview-with-steven-huang-of-audio-sensibility/
https://audiosensibility.com/blog/technology/ohno-continuous-casting-occ/
https://audiosensibility.com/blog/2017/04/19/sad-news-dr-atsumi-ohno-passed-away/
