Additionally:
Last Device Instance Id: USB\VID_16D0&PID_071A\413-001
The 413-001 is the serial number
My Hardware Ids from a stock DA004 are:
USB\VID_16D0&PID_071A&REV_0196
The REV_0196 is the firmware installed on the Combo384.
Can you report the Hardware Ids?
Yes... REV_0197 may cause a problem.
If possible please use Maintenance Tool 1.17:
CPLD Firmware Selection: CPLD_for_1080
Flash this version associated with CPU firmware 1.080 with prescaler option
CPU Firmware Selection: firmware_1096c
Long mute 100-200 ms F0-F3 already enabled fixed compiler optimization problem
This should solve your issue.
Don't know if I would recommend it, but I have an Oppo 105 and I also use an ASUS e403sa laptop with a Toshiba hard disk to feed the USB. Originally the USB set-up was for playing ripped SACDs which could not be sent to the LKS through the Oppo. But I got a lot of advice that the clocks on the Oppos are not really good and that I should get a better CD transporter for playing disks. What I am doing instead is ripping all my CDs (a long and tedious project) to the hard disk and playing them through the USB where they are re-clocked by the very good clock on the Amanero. I do think they sound better. Since I eventually wanted to rip the CDs anyway, it was a no-brainer.
The Allo USBridge consists of a Sparky SBC and a USBridge daughter board with USB connector. The USBridge reclocks the USB and reduces noise to a very low level, ideal for a USB DAC input. Music files can be on a hard drive or NAS. Players, software is Linux based distributions, DietPi or Volumio 2. I use a NAS and Volumio. Depending on the DAC DSD may be supported to DSD256 in the Linux environment.
anyone tried turn the vol of your amp to max with l.k.s.004 and play nothing? is your noise obvious? my one is quite obvious. if i switch to other vacant input in amp, much quieter.
