fmzip
- Jul 7, 2010
@b0bbThis happens on old caps where the rubber seal may have shrunk as it aged, you will be ok with a cap made in the last 3-4 years, check the datecodes on the caps you intend to use.
ESD bag will not help much if the electrolyte touches the board, will eat the copper clean off the board, does to same to skin.
I have these in new date codes, can I use any/all/none of these choices:
109D107X0025F2 100uF 25V 20% (7.92 X 20.22mm) Axial 4 Ohm
109D157X0030F2 150uF 30V 20% (7.92 X 20.22mm) Axial 2.5 Ohm
109D277X0050T2 270uF 50V 20% (10.31 X 23.4mm) Axial 1.8 Ohm
109D567X9025T2 560uF 25V 10% (10.31 X 23.4mm) Axial 1.8 Ohm
109D337X0030T2 330uF 30V 20% (10.31 X 23.4mm) Axial 1.8 Ohm
109D107X0060F0 100uF 60V 20% (7.14 X 16.28mm) Axial 2.5 Ohm
109D477X9030T2 470uF 30V 10% (10.31 X 23.4mm) Axial 1.8 Ohm
