MartinWT
Yes, agreed. Good power cord, running from a regenerator, makes a big difference. So was changing from single-ended to balanced cables, good ones.far less than changing to quality interconnect and power cord.
Thanks, I'll do that.I just disconnect the power supply leads to the Amanero
Pangea HDMI is recommended
Dear Forum Members,
for 2 years I am now a LKS 004 owner. I was overwhelmed by the sound quality. And I still am. I am also a DIY Speaker builder. So as my speakers got better and better,
I thought maybe I could improve something else in the Chain. So first I added a ifi iUSB micro witch made a huge improvement in soundstage focusing!
Then after searching for 004 tweaks I ran across this forum. So I read this forum and the 003 forum twice. Very interesting, so I tried some of the tweaks that where published here.
Here are my findings :
- I do have a USB upgrade board installed in the 004. The default PS is with OP177 and LED. First I measured the output voltage and was very surprised, it is 4V NOT 5V.
Well anyway, tock the LT3042 PS I ordered in China and replaced the OP177 board with it.
Hocked everything up and listened to my reference music. It was disappointing.
Sound was lacking Bass and upper Bass. But resolution was better. I remembered that someone in the forum wrote that the 004 is very sensitive to HF. I decided to shield the AC cable that supply’s the LT3042 PW Board, and added some Tantal Capacitors to the Clock Board. Thigs got better but still poor Bass performanceL.
I ended up switching back to the OP177 PS Board. ( What did I miss ?? )
- Sense I am a Design Engineer for electronics, and I used to develop high resolution ADC’s,
I know that vibration is a big problem with ultra-high accuracy circuits. So I decided to install a dampened Sandwich bottom to the 004 DAC. All femto clock and ultra-low noise Application notes mention that Seismic vibration is one of the biggest problems in measuring the specs of these circuits.
Wow what a difference. Big soundstage, very clear. Very stable imaging.
BUT: much too much high’s. Too much high frequency energy L ( What am I doing wrong ?? )
I now ordered a Singxer SU 1 to find out where the problem is.
Dear Forum Members,
Yes, as @Whitigir mentioned, remove the 575 and solder in the 950XIs the CCHD950X a direct plugin?
Solder it directly unless you want to experiment with different XOs.Is it best (or more importantly easier) to mount the 950x onto an adapter or can it simply be soldered directly?
I'm interested in your suggestion of 'thermally coupling both halves of output stage on the I/V converter.'
Is this a procedure you've explained in a previous post, if so I'll try and track it down?
If not, what exactly does it entail?
Cheers.
