MacAttack7
Thank you. Didn't realize the mesh comes with glue. I don't notice anything bad about the sound now that I removed the mesh on the left side, but I don't think I have the best critical listening since I usually like earphones that receive horrible reviews.You can be a good critic of AS16 pro, looking forward to your impressions.
Please try AST with 30 Ohm and possibly with 48 Ohm - you may like it much more. Though all of these IEM are far from basshead and geared more to classical/acoustic music.
Sorry to hear about it!
The previous mesh was more open and better then.
First, if it helps I run my two ASX without any mesh (totally freeing the sound), iit works OK given ear wax is not much of a problem.
AE sells IEM mesh already with the glue and at very reasonable prices: here is the link.
You need 5.0 mm for AS16 pro, the opening is a bit larger - 5.1 mm or so.
I can't tell...is the mesh screen on the AS16 Pro metal or something else. I need a magnifying glass as it's hard to tell.
