Does the AS16 Pro fit your ears well?
Maybe my ears are just too small, but the shell doesn't even touch my ears.
The nozzle is the only thing holding the IEM in place, while the shell just kind of hangs in the air.
They seem to stay put well enough when sitting still as there is a bit of suction, but I wish they fit me better.
(By the way, my left earpiece went way down in volume. Volume was almost completely gone, then came back some a few hours later, but days later it's still extremely low compared to the right side. I think they are sending me a new left side earphone. I had to make a video blasting my earphones at full volume, so they could hear the problem for themselves. Hopefully that didn't damage the right one.)
AS16 pro have exactly the same shell as AS16 and many others KZ/CCA IEMs: AS10, AS12, C16, A10, etc.
My first KZ IEM was ZS10 (not pro), just a bit larger than AS10 but surprisingly harder to fit for me. (Never cared for ZS10 sound, way too loose bass for me, but learning to fit it was valuable). What worked for me was to use larger tips. My ears are fairly large but they totally detest any idea of deep insertion, so large tips (including huge 14-14.5 mm for smaller shells) work well for me.
Returning to AS16 pro, it fits me very well and provides very good isolation (too good to use in the city streets). Perhaps, my ears were trained with happy 6 months with AS10 first and then another six months with C16.
Coming from Fiio F9 pro before AS10, F9 pro by its smaller size fitted well, but did not work well with the nozzle angle and overall, AS10 was a bliss of secure fit comfort.
AS16 pro in its "as is" state (without adapters) reminds me a lot of AS10.
I will surely get the "30 Ohm" one, thank you for the tip/info
@baskingshark !
I still could not find it to be available, count on you for the updates.
I could have got my second pair of AS16 pro a bit too early
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
Well, you can laugh at me, when I first ordered AS10 on eBay at $45 I was worried about counterfeits. Then, I could not believe the sound for $45, and ordered another one right away. It is still unpackaged, since the first one took all the abuse and still goes strong (that I did not take for granted for $45).
So my two happiest ChiFi stories so far are KZ and Tempotec (for the latter I got through my mini "dongle mania" (20+), and in the end E44 and BHD are my favourite pair, and V1A is a fantastic little transport).
