Viber
- Jan 28, 2008
Found this review on KZ VX10:
https://www.facebook.com/104164698111775/posts/361832799011629/
KZ VX10 Features
* Drivers
1x 10mm Dynamic Driver
4x Balanced Armature
* Bluetooth 5.2 with Game Mode
* SBC and AAC Coding
* 4hrs Battery Life upto 20hrs Total
* Frequency Response: 7hz-40khz
* IPX4 Water Resistant
Whats in the Box?
* KZ VX10 Charging Case
* Silicon Tips(Small and Large)
* Short Usb Type C cable
* Multi Language Instruction Manual
Build and Design
* Ok lets start with the Case, this design is used and abused from Z1 pro, SKS, SA08 and now VX10, Circular Design with Matte Finish
A Standout Design for a Flagship True Wireless Earbuds should have been made for VX10.
It Lacks special features like Dedicated Pairing Button, Quick Charge, Wireless Charging and External Battery Led Indicator.
KZ Signature Earbuds Design, Customized IEM like and Glossy Body.
But "10 Drivers" printed in the Faceplate? I think we would like to see "VX10" and "KZ" printed in there just like what they did with SA08, that would be cool.
After all that said, Its Utilitarian nothing more, and Its OK.
Sound Quality
* What are your Expectations in a Hybrid 10 Driver True Wireless Stereo Earbuds?
In this Department it does not Disappoint, KZ VX10 Dynamic and Balance Armatures are put into Good use, this is where it Flex its Muscles.
You get alot of Bass, Details, Separation, Clarity, and Wider Sound Stage, Sounds are so Crisp and Loud Volume.
This have a Mild V shaped Sound Signature, Boosted Bass and Treble, Mids are Good.
You get a lot of Volume with KZ VX10,
Indoors 40~50%,
Outdoors 50~60%
this TWS is pretty loud, and you will have eargasm while using VX10.
On Low Volume, you can hear some electronic noise(hiss), it easily drowns as the music plays, it is not as bad as KZ SA08 where you can hear it too even at Loud Volume.
Fit and Comfort
* VX10 is like In Ear Monitor with a customized design that will snug fit in to your Ears, and gives a good amount of Physical Noise Reduction.
The Design is quite bulky and will stick out of your ears, and it can hurt your ears if you are not used to it, but its quite alright.
I have used it for more than 3hours straight, my ears did not hurt or had a fatigue.
The Touch Controls are responsive, give you a confirmation sound for controls and they are not sensitive if you are going to to adjust them in your ears.
Included Silicon Tips are Comfortable but lacks Isolation, its Thin and Soft.
Battery Life
* It is Rated 4hours upto 20hours, I have manage to get 3:40mins @ 50~60% most of the time for Music and Watching Movies
For most Casual users this is OK, but for Power users this is below average.
Battery life during Game mode will drain much faster, so try to monitor it during long Playtime.
VX10 Weak Point is low battery life because of those Drivers draining that small amount of Internal Battery.
Connectivity
* Another Strong Point for KZ VX10, It is equipped with REALTEK chipset and Bluetooth 5.2, and supports SBC and AAC only, sorry no APTX here.
Solid and Stable Connection, It's pretty rare to experience Dropouts.
Including Gaming Mode, No Screetching Sounds during gameplay, Drop outs is also rare.
The Connection for VX10 is so solid that I need to say it twice in this review.....
Gaming Mode
* It Reduces Latency a little bit, It is hardly to see the delay while playing League of Legends or Call of Duty.
Also during these mode, Battery drains faster, and you might experience interruptions and dropouts
Gaming mode in general is very sensitive to radiowaves, open signals, wifi and bluetooth.
Call Quality
* Its Clear on both Ends and Voice is Natural, and I think this one have some Environment Noise Cancelling it does work well, it blocks some of the background noise, but my Voice feels like I was far away from the Microphone.
Overall Call Quality is Great.
Whats Good about KZ VX10?
* Sound Quality!!! This is what you are paying for, those Drivers inside the Earbuds gives you what you need to Hear.
No Fancy Case, No Fancy Tech just Pure Sound Quality, this is how a Multi Driver TWS should be done.
Did I already said about the Connectivity? How Solid it is?
What' Bad about KZ VX10?
* Love it or Hate it, KZ Signature Design is already Old, it needs some Fresh Design, just like what they did with KZ SK10.
The Charging Case Lacks Functionality, its just a case and nothing more.
Verdict
I really Love KZ XV10, You get Great Sound Quality, Solid Connection, Good Call Quality and Game mode that Works, I can ignore the Charging Case and the Design.
If you have Spinfit 360, replace the stock tips immediately, and you will get better experience.
This is my Favorite KZ TWS right now.
Price of KZ VX10 as of writing Php 2,899
