SpaceOperaVillain
Yeah, the KBear NEON. I've been meaning to listen to that again.
All mids and treble. \o/
Do you think we can convince KZ to bring back Starline tips and discontinue the nasty white ones supplied with the latest KZ/CCA models? I fitted Starlines to the NRA and the sound was transformed.
Simply put on the filter on the iem nozzle.Never modded IEMS, how this filter thing works?
Any sense if the AZ09 Pro is any better? I agree 100% about the AZ09 BT issues. I’m hoping the pro version might be a little better.Mine AZ09 sucks. Connection drop alot even when the transmitter like 1ft away from it.
What I like from AZ09 better than BT20s pro are:
1. Much compact size, hard shell case and better IEM placement inside the case. On the bt20s pro, your iem will get squished out and if the case got crushed by something quite heavy, it can break the iem.
2. The module is smaller and lighter than bt20s pro.
3. The fit on the AZ09 is better and also it doesn't move around much if you are running or jumping than bt20s pro. The bt20s pro seems loose and just hang there. I did try bench pressing with it and the module since it is heavy, it tends to hang loose.
4. The AZ09 has higher output than bt20s pro, but this can also make the hiss more pronounce in sensitive iem.
Now for bluetooth range, the bt20s pro wins by a margin. It has AptX instead of just sbc and aac. Battery life from bt20s pro is around 6 hours+, can't say about the AZ09 as I haven't had the chance to try it for longer than 30 minutes and had to take it off because of connection dropping.
From my experience from KZ bluetooth anything, their connection is kind of suck imho. I have the bluetooth cable (HD and non HD) and the connection will cut out when you hold the module in your hand even when your source like besides it. Tried to cupped both my ears while using the AZ09 and true enough, the connection will cut out.
I don't know. Is the pro version come out already? At home, the AZ09 is okay, but when I went outside, the connection got really really bad.Any sense if the AZ09 Pro is any better? I agree 100% about the AZ09 BT issues. I’m hoping the pro version might be a little better.
This was on Facebook today…I don't know. Is the pro version come out already? At home, the AZ09 is okay, but when I went outside, the connection got really really bad.
Oh more expensive than the original AZ09. Does it have AptX? All I see is they have a B-pin and C-pin option now.This was on Facebook today…
Not sure about AptX.Oh more expensive than the original AZ09. Does it have AptX? All I see is they have a B-pin and C-pin option now.
Finally they used the "now" standard QC3040...
It should be good. Do QC3040 support LDAC?
btw if 3040 is the "Pro", the QC5100 will be AZ09 Pro pro?
Btw KZ seems to relatively release this in silence? KZ VX10
It came with interesting claim
According to this, it does have AptX. Hope it’s true.Oh more expensive than the original AZ09. Does it have AptX? All I see is they have a B-pin and C-pin option now.
