wow - great feedback in such a short time!
Night Lights from Jerry Mulligan Sextet is a good example. Acoustically there is a lot happening on this recording, and you need a bit of elevated treble to hear it. I am a former low brass musician (another lifetime by now) and when that low raspiness of the tone's edges are missing at low volumes it makes me want to throw things. x-D If your phones or speakers don't have good instrument separation, it will blend into the snare brush and just sound like static. Now, above that, when the piano comes back on, listen out for those delicate strings supporting the melody in the left channel. The C12's excel here (way better than $35 has any right to) relative to a lot of things.
Classical - Isle of the Dead, from Rachmaninoff. The dynamics in this track destroy the illusion of quality in a lot of setups. Timpani can disappear into the brass. Crescendos distort. Sloppy subbass screws up the plucking on contrabass. When things get going and the orchestra begins to really send the beans at the 7 minute mark, if your speakers have bad instrument separation, this will just sound loud and terrible. C12 is just barely adequate here. The bottom end of the orchestra could be tighter. Compared to my old Shure SE315 or AKG 702 it's not nearly as tight as it could be. Compared to overears like Shure SRH840 the bottom end is 1/2 missing. Soundstage is acceptable for an IEM, but more width would help keep the busy parts from stepping on each other.
Piano tones and simpler arrangements are all fine. Opera vocals are enjoyable. It's really just big orchestra that trips up that 7mm dynamic. FWIW, it's the same for fast metal. The Last Baron from Mastodon is a good example. Both guitar parts have good crunch and detail, vocals are good, all the crazy samples can be picked out ... but the bottom end is just like 3/4 there. KZ foams (the pack sold separately, not stock ones) and the KZ starline silicones both give a good seal, but the bore is a bit deep and narrow. Might need to try one of the shallow-wide bore tips to see what happens.
Thanks for chiming in Nimweth, i've enjoyed your reviews. what balanced cable would you rec for the CKX? I'm using BTR3k mostly right now (ordered w/ the C12). It's great. I was going to pull the trigger shortly after on a Qudelix 5k to compare, but it seems pointless for sensitive IEMs. Bluetooth LDAC from my laptop w/ bt 5.1 is silly levels of good for the cost. Even though these are sensitive, I find that I'm pushing volume on the 3k pretty hard. I go to max then click 5 down from peak volume. I thought that maybe a balanced cable might add back some bass.
I have all of these including the ZAS in my cart right now on AliExpress
but my wallet says I gotta choose! I was stoked about DQ6 but after being so disappointed in Blon BL03 I thought I'd relegate myself to hybrids or full BA setup. After burn in and spending time with them, C12 is what I'd consider to be a
very good, but not quite great.
Outside KZ/CCA there isn't much that's caught my attention besides Shuoer Tape. From what I've read I don't think Moondrop Starfield or Blessing 2 is an upgrade for me, even over the C12. People seem to like the timbre and relaxed tuning on these for pop / rock more than anything, which is cool, just not what I'm looking for. I don't think an EQ preset is worth $500-$1500 premium.
