I know both me and the shop are being overly efficient this time...
11 Resistors and 2 Caps?
They are really light, almost too light and plastic. Definitely not a successor of the ZAX but the CSN.
Impressions so far?
hmmm...not too impressed, lol. For now I prefer my modded CSN. I don't hear much difference between this and the stock CSN.Impressions so far?
Got the black/gold incoming. Good thing that even the mid-tier KZ's now come with a better cable. So it's warmer than the usual V tuning? More relaxed treble?I know both me and the shop are being overly efficient this time...
Just a bassier version of the CSN? And you need a bass heavy track to hear the difference. Mids are also slightly thicker but not by much.I know both me and the shop are being overly efficient this time...
I think it wasn't exactly like that, The BAs don't really do anything in the CSN I think.Got the black/gold incoming. Good thing that even the mid-tier KZ's now come with a better cable. So it's warmer than the usual V tuning? More relaxed treble?
Might the BA be also taming the highs just like in your findings with the CSN?
Oh, my bad. Must have mixed up the results of your testI think it wasn't exactly like that, The BAs don't really do anything in the CSN I think.
Not really. It is very confusing. I mean the BAs don't make a sound as I could not hear any difference between the left (stocked wired the BA in phase) and right (stocked wired the BA in antiphase). I replaced the PCB and then I could hear the difference. The QC or maybe the design is really making it very confusing.Oh, my bad. Must have mixed up the results of your test
A skip for me already lol. Cheers for the reply.hmmm...not too impressed, lol. For now I prefer my modded CSN. I don't hear much difference between this and the stock CSN.
Seriously, get a pair of CSN and just simply replaced the stock PCB, also check the wiring of the BAs you should be quite satisfied.A skip for me already lol. Cheers for the reply.
I already have the CSN. Are they easy to open up then? I have never swapped a PCB before.Seriously, get a pair of CSN and just simply replaced the stock PCB, also check the wiring of the BAs you should be quite satisfied.
Seems like a fun pastime, but not necessarily the most inexpensive way to get a nice set of IEMs. Still, a valuable experience and a nice entry into tinkering to make your own IEMs down the road.Seriously, get a pair of CSN and just simply replaced the stock PCB, also check the wiring of the BAs you should be quite satisfied.
First heat with a hairdryer to soften the glue between the shell and the metal cover. Then carefully use a cutter (or much better with a scraper knife) and insert it into the slit between the shell and the cover. It is best to start from the top as it is kind of an even surface. Then you should see a free floating PCB there connected in series with the 30095 like this +ve -> 20ohm -> 330nF - +ve BA. I fabricated PCBs with those PCBs with a lot of holes myself to make the soldering easier. Also, I used metal film resistors and ceramic caps.I already have the CSN. Are they easy to open up then? I have never swapped a PCB before.
To be fair I think the BAs in there may need some time to run-in and to settle but so far I think the 50024s are not bringing extra definition and dimensions to the mix, actually the other way round. It is easy to hear that there is more bass but the extra bass is making the punchy bass of the XUN driver kind of blurry. There is also clearly more mid but I find the mid plastic sounding, for now. I hope running-in will make some improvements. Will also compare with the AST soon.Just a bassier version of the CSN? And you need a bass heavy track to hear the difference. Mids are also slightly thicker but not by much.
The array of 50024s are there to add bass? Just like in the AST?
Another graph of the ZAS for comparison... Directly from KZ.
