I have finally received my package with KZ ZAX, Ibasso DC03, KBEar 16-core copper cable and Spinfits CP100/145/800(the latter was a wrong choice but it's too late).
So uh.
My micro review: KZ - "ZS5v2 vs ZAX".
No "wow effect" right off the bat and mixed feelings. But!
It was immediately noticeable that ZAX is waaaaaaay more comfortable than ZS5s that have their
sharp shell design stolen from CA Andromeda. Even though ZS5s were exceptionally robust(except for the nozzle, ha-ha), I don't think I would pick them again for their comfort, ZAX on the other hand...
Right after that, it's easy to notice that
ZAX is way better in terms of details and superior in instruments separation. An example that I used for testing instruments separation was "Lilium - Sleeping Inside" - even through YouTube "quality" sound it's really noticeable. I wasn't completely stunned by this, but it was a surprise nonetheless.
Subbass seemed to be lacking remarkably on ZAX, though. This issue was fixed by replacing the stock Starline tips with foam tips that I'm already quite familiar with.
This slightly elevated the bass, and I also had a better fit, because out of the box ZAX comes with M-sized Starline tips and my ears are only comfortable with L size.
I didn't believe in that at first glance but
replacing the stock cable with KBEar 16-core
followed with an improvement in the bass frequencies.
This cable came with the additional soft bag as a gift. Which is a really nice move from the manufacturer, since you're buying an upgrade cable, this means you already think about your earphones and their quality, and you need to store them somewhere, right?
But even then, it seemed that ZS5 is better in low frequencies, at the same time
ZS5 is muddier than ZAX probably because of 2 DDs versus 1. Well, of course, the difference is in their overall construction & setup too. ZAX has more space inside, has x3 times more BA drivers. Also, ZAX seems to be more punchy in the entire spectrum. Especially on any drums(cymbals) and on the bass. I'm not sure if that's the right word, but their speed characteristics feel generally better. After listening for 40 minutes, I started to have some sort of a headache - my ears adjusting to a new sound or something else, but it's just a thing to notice. Later on, I didn't have pretty much any discomfort.
I have tried stock Starline tips, foam tips that were included in the package by the seller as a gift(these ones are your more standard-ish foam tips, they have this slow memory foam effect, I used to own a similar pair but they were more sturdy and I bet they would sound better). Finally, we have Spinfits CP100 - I had a feeling that low and mid-bass aren't just there, I have replaced them with CP145 and "wow" effect came in. I bet it's because of the fact that their nozzle is wider.
Sound is well-detailed, crisp and bright. There's no "overwhelming bass" that people were telling in their full-of-hate reviews, mids are relaxed but not really drowned & veiled. Fit is comfortable. They're not completely closed and they, indeed, lose some of their isolation. For example, without anything playing, I was able to hear some noise coming from my PC. Again, foam tips would have probably fix that. There are some signs of sibilance here and there but not nearly as terrible as with ZS5v2. I can't say that ZAX just completely eliminated ZS5v2 in every aspect, I would say ZS5 were already
absolutely insane for their 28$.
I also do think that by replacing all BAs in ZAX for Knowles we could probably have an entirely different level of sound. With the price skyrocketing at up to 12 or 15 times more.
I would absolutely recommend the cable I mentioned because it's really soft and looks superb.
Testing tracks:
CHVRCHES - Never Say Die:
(my crash-test of any earphones on the planet, if there's sand or sound gets mushy on the chorus - test failed). I think they passed, but they have slight issues with the vocals and upper mids. There's a lack of brightness, but hey, a horrific amount of sibilance with a lot of air & brilliance coming from ZS5 or the more balanced sound of ZAX. My brain needs to readjust itself to something flatter on highs.
Bury The Light(OST from Devil May Cry V):
There is no lossless version, which is very unfortunate. But still, there are issues with mids and upper mids. I can't get my head around why they sound relatively bad on this.
MOON - Hydrogen:
My usual track for bass testing, I know there are better examples in different genres, but I'm stuck with this one. They sound great on this, but it was highly expected.
I was also trying some EDM music, I guess EDM is a sweet spot for these. Just because of "Bury The Light" I think metal music will be difficult. Pop music sounds great, too. I definitely need to check some classical music & jazz.
This was the 1st day. If things would be better, I will make an update post.
