Nimweth
.....or Spiral Dots!Of all the things i've wanted to be. I've never thought of being an iem.
Just kidding, i have the zs7 and can vouch for that with swapped cables and spinfits!
For anyone like me who still needs a microphone in their cable, I just discovered these two cables, I don't know their quality yet but I ordered them and when I receive them I'll tell you if they are worth it.
2 pin 0.75mm to 3.5mm Earphone Replacement Earbuds Exchange Cable w/ 3 Remote Buttons Gold Plated Straight Plug for KZ ED12 ES3
http://s.aliexpress.com/beYVVbEB?fromSns=Copy to Clipboard
2 pin 0.75mm to 3.5mm Earphone Replacement Earbuds Exchange Cable w/ 3 Remote Buttons Gold Plated Bent/Straight Plug
http://s.aliexpress.com/Un6bAJ3q?fromSns=Copy to Clipboard
I am sure they won't be as high quality as some other cables available, but I am very happy that I found cables with 2 pins and microphone with volume keys.
QC issues with Chi-Fi? Surely you jest...Just received my KZ ZS10 Pro and KZ Silver Plated upgrade cable (bought both from the same seller).
I know these are <$50 and I shouldn't be too picky and that's fine, but I'm just noticing a couple of things that might suggest i've got a 'factory second' or a refurbished stock...
Here are my issues;
- There is some pitting on the left earphone in the left earphone (circled in red), is this a QC issue?
- I ordered the KZ Silver Upgrade Cable from the same seller, and the box for the cable came shrink wrapped in plastic however my ZS10 Pro box did not come in shrink wrapped plastic.. Seems strange that they would only shrink wrap some things. Does anyone remember if their ZS10Pro also came shrink wrapped or not? My fear is mine was previously opened. Picture of the Silver Upgrade Cable box with shrink wrap that was not present on the ZS10 Pro box:
- There is no Left/Right marking on the IEM's themselves, only on the cable. Is that normal? Online reviews suggest there is some marking on the IEM's too
I personally use missdoku (something like that) extra large tips because they are cheap, they sound good, and they fit my cavernous ear holes. I think they are 14.5mm wide. Also x large tips are hard to find. They fit on all my kz models. I think I've owned 6 kz earphones.
Here are my issues;
that is pretty normal in chifi QC, dont expect them like a very big brand. as long the sound is OK, well put anything aside, lower your nitpick standard buddy. as for shrink wrap plastic, unfortunately yes, the KZ IEMs should be come in wrapped plastic from factory.
Great thanks. yes you're right, I shouldn't expect too much at this price point.
Regarding the shrink wrap and possibility of this being opened stock, should I contact the seller? Wish me luck with the language barrier...
How to tell L from R:
1. Hold up the IEM so that the ‘pointy’ part of the shell is facing down.
2. Now look at what direction the nozzle/eartip is pointing towards.
3. If the nozzle/eartip is pointing to the LEFT, then that’s the LEFT IEM shell.
4. If the nozzle/eartip is pointing to the RIGHT, then that’s the RIGHT IEM shell.
Scientifically, at 30 Ohm specified, cables should not matter that much for ZS10 pro.dh0licious is there any difference in sound quality between stock brown cable and the silver upgrade cable? thanks
