Jan 9, 2020 at 1:32 PM Post #49,261 of 67,809
Where can I buy stock tips from KZ ZS10 PRO? They are starlines but smoother and better than regular/old starlines.
Actually, the best Starlines are the ones from the ZS4 and ZS3E. I’d buy a suitcase full of them if I could find them sold separately.
Jan 9, 2020 at 10:53 PM Post #49,262 of 67,809
Question guys, do you recommend the KZ ZSX or ZS10 Pro? I am searching for new IEM since my ZS6 died after I think 2 years of use.
ZSX pros against ZS10 PRO : better timbre, no more metallic sounding especially on high frequencies, more balanced signature, better soundstage and imaging,
in other word ZSX is a perfection of ZS10 Pro, but the fit. ZS10 pro is much smaller and easier to fit. ZSX fit isnt bad, but they have protrude like custom IEM and have bigger shell
Jan 9, 2020 at 11:16 PM Post #49,263 of 67,809
I want these ZSX pros you speak of that don't exist :)
Jan 9, 2020 at 11:29 PM Post #49,264 of 67,809
Jan 10, 2020 at 12:05 AM Post #49,266 of 67,809
What is the very best KZ at this moment? im really enjoying AS10 with foam tips (much better bass presence) If you have as10 and didn’t try them with foam tips try it and tell me if you get much more natural bass
ZSX
Jan 10, 2020 at 12:09 AM Post #49,269 of 67,809
Some say that the KZ ZS7 has the most bass.
If you're like me, and that's what you're after, then that's the best KZ IEM right now.
Jan 10, 2020 at 12:16 AM Post #49,271 of 67,809
Snippy aren’t we? It improves soundstage but the downside is sound leakage. Same as normal headphones.
if you have any IEM that are vented put your finger over the vent and see what happens.
I'm aware of the pee holes in IEM's and the various purposes they serve depending on position, some actually don't do anything at all and are for looks (the large ones on some shells). I wasn't trying to be snippy. I just wanted to see what you had to say.
Jan 10, 2020 at 12:18 AM Post #49,272 of 67,809
If I bought iems because the vents in the picture and they were just for show I’d lose it. Once you hear the soundstage of a truly vented IEM it’s hard to go back to totally sealed. At least for me
I just bought some ZSX on amazon. They’ll be here tomorrow
Jan 10, 2020 at 12:30 AM Post #49,273 of 67,809
Nice they have large soundstage despite with minal vent holes.
If you like semi open back iem, try **** pro
Jan 10, 2020 at 1:44 AM Post #49,275 of 67,809
Agreed.
The ZSX are so good.
At the time of ZS7 I thought they were absolute monsters, listening to them now I prefer the ZS6 and comparing with the newer ZS10 Pros and ZSX there's no chance for the ZS7, at least for me.
I love bass and sub-bass but the ZS7 have a strange tuning that I still did not understand.
I don't mean I do not like them, but there are better choices around.
They're sub-bass cannons and love listening dubstep on them, but dub growls and synths are just so much bettee on the ZSX. Plus, the ZSX are not so deep in terms of insertion, and this is really something to consider for long listening sessions.
I cannot say that the ZSX is the best KZ nowadays, moreover because I did not listen to AS16 and AS10, so I cannot speak about something I do not know.
What can I say, objectively, is that the ZSX is a real bargain.
Check the TRN V90 as well, they're good as well (and much more comfy than the ZSX sadly).
