Well I think KZ is the only winner in this situation as they earn a cut no matter who buys what.
But I feel sad for the other companies that get their sales and customer base diluted.
As for consumers, just go to AE and search for the cheapest of the 3 to purchase LOL.
How close do the TFZ No 3 sound to the KXXS? Apparently they sound similar but something about the No 3 sounds really harsh and fatiguing to my ears. I get no fatigue from the ZSX despite the forward sound
I'm the opposite. I find my No.3 too laid back with not enough detail for me. It's a great basshead iem for sure, but it's kinda a one trick pony imho.
thanks for this, alright thats what i need to know, I dont need louder sound from BT20 as i never past around 90% volume. I just upgrade when my old BT20 down someday, or any significant upgrade with new model.
so my 2 pin BT20S has just arrived. testing it with the ZS10 Pro, and it has a really low noise/hiss, while on the old BT20 there are no/negligible hiss. both sound similar, although (might be because of the hiss too) the newer BT20S is slightly more recessed in mids, but it might be totally subjective. someone with measuring rig might give a better answer.
i ended up using the BT20S with the Kanas, and the older BT20 with my EM2
I don't think its harsh because it has a lot of detail, it literally just has a harsh tone in the upper midrange that is fatiguing. It's treble is laid back, it is just harsh or sibiliant or something like that, it has nothing to do with resolution or treble forwardness. Like I said the KZ ZSX are not fatiguing to me, even though they have more detail and more forward treble.
Yeah if it has a cable around the neck, it's not worth it, you might as well just get an es100 and a shorter cable if you want. Things like the bt20s are so cool because it is basically true wireless
is it the neckband ones? i like that form because it usually can connect to two device at the same time, but the added cables (compared to the BT20s) means a discomfort for me, and at that rate i would prefer just go with the ES100 solution instead
i choose the BT20s mainly because of convenience and mobility
It's the first time where they tune exactly the same. usually they have same hardware but slightly different tuning ( CCA C16/KZ AS16 l KZ ZS7 / CCA C10 ) KZ ZS10 PRO / KZ ZS10 l KZ ZSN PRO / CCA CA4)
There's this post where KZ made some OEM identically tuned IEMs for 3 companies:
Tripowin TP10, the CCA A10, and the KBear KB10
Just the brand name is different.
And the tripowin have bad notes, CCA it's good. It's fun because it's exactly the same thing. Just the faceplate which is different, but because the brand is new, they are trash.
I hate most of neckband Bluetooth cable. They use Qualcomm dac which are crappy. Hiss ( KZ 5.0 have a horrible hiss) , electronic noise, dac quality just correct. I prefer clearly TRN BT20. Bt20S is worst than BT20 on this point too.
I wait macaw cable with a real same integration ( Maxim dac, like in some oppo/Samsung smartphone )
Those TRN BT20s are the real deal, I have a pair of the older 20 and the newer 20s and both work great. I thought about getting KZ's BT cable for my ZS10 Pro but I've heard they don't work so well? Plus cables, pfft.
Anyway the KZs go on the BT20 while my iBasso IT03 goes on the 20s, very happy with their performance.
About to order the KZ ZSX from their official Aliexpress store. First time ordering from there for UK. Anyone had any issues?
Also, since I'm hearing a lot about cables - is there something specifically recommended over the default cable for genuine improvement?
Thanks.
Thanks.
We order many things from Aliexpress. We use the NiceHCK the most ... good service and fast shipping. We do use other stores as well. This is kind of like using Amazon third party sellers.
If you "follow" the store you will see the fans exclusive discount... price will be around $39
