Well, most ppl here think of ED9 rather as brighter sounding IEM than neutral. ANV is what I would call flat/neutral.
But of course... depends on gear being used, music, hearing, tips used, file format etc.
The description for those explains the difference between the 2013 and 2014 models. Would explain why my second pair sounds noticably better than my first pair.
I had the KZ ED9 but just didn't like the sound, I changed filters added and removed foam and generally messed around with them for hours but the treble was just too splashy and piercing at times, I didn't like the way vocals sounded on it and to be honest it wasn't even very comfortable to wear and a bit on the heavy side.
But caught up in the spirit of adventure I have just raided Aliexpress and ordered the ATE and ANV along with the MOAL M850(dual driver) all for bargain prices and fingers crossed I can get along with them better than my ED9s
Wait, what? There are two different versions? I bought from here: http://www.aliexpress.com/item/KZ-GK-ANV-Aluminium-Alloy-Professional-Noise-Cancelling-Dynamic-Balance-HiFi-Heavy-Bass-In-Ear-Stereo/32221572219.html#feedback
Wonder what version I have? From description looks I bought 2014 version but not sure, hard to understand such text.
Some stores mention 2013 and some mention 2014. My first pair were the 2013 version picked up from the first "official KZ store" before they reworked. Can't recall where I got the second. There were noticeable sonic differences between the two: most obvious was that the new one had cleaner, more controlled treble. Felt like a they had a bit more sub-bass as well, but this I'm not 100% sure on. Pretty sure my second pair are a 2014 version.
Edit: reading the description I think you got the 2014 version.
It seems every time the newest KZ is the best but then it turns out that an older one is still a bit better... hard to look through the hype. Personally I think the KZs dont differ to much in sound quality, they do differ in their frequency responses though. So get a KZ that fits your likings, and be happy with it
Those who wish to try, KZ ANV is selling for 9$ atm: http://www.aliexpress.com/item/100-Original-KZ-ANV-Grade-Fever-Linear-Equalizer-Ear-Earphones-Monitor-Headphones-Perfect-Sound-Dynamic-Structure/32317811425.html
I have the GK's & they are superb, Basically Flat, with tack sharp resolution equaling the Havi's. They have an ENORMOUS Bass when called for, Like I said in a previous post I believe they are grossly under speced in their Bass Frequency limit. BUT it doesn't get in the way, nor does it dominate the other frequencies. Does that make any sense at all? These are the first earphones I have had that almost give you that sub-bass slam you get in the chest from a Big Home Subwoofer.
Clearly my Favs so Far. I got them from the Seller in the 1st Link Coil posted. The way I read it is they changed them in 2013 to the new version. Just like McDonalds: xxxxx Billions sold.....
If you have any doubts, buy them to compare with the ones you have. I didn't know there were 2 Versions.
KZ really needs to get their descriptions and naming straight. The descriptions don't make any sense what so ever ("Super bowl augmented mids sound effect", what the..?), and if they've made improvements on an earphone, it should be in their best interest to be clear about this in the naming, i.e. ANV v.2 or something..
Anyway, I hope the ANV I ordered is the new version, at least it had that same description that mentioned 2013 and 2014 in it, the rest of it didn't make too much sense..
