The replacement for my KZ APTX HD Bluetooth 5.0 cable arrived and it's fixed
Previous post with pictures)
Initial impressions using ZSNs comparing between the old and new adapter (around 30 mins of back and forth listening):
- The cable has a little more give than the previous APTX adapter (2 pill) and no memory wire in the new model is a welcome change.
- Still says "Turn off" on power up... Come on KZ not even a handful of phrases and making translation errors...
- There is more clarity and separation. In comparison, the old adapter sounds a little muddy.
- The bass has a little more depth.
I can't really tell a difference in sound quality between a cable and the adapter when using my phone (Redmi Note 7). Overall sounds quality is very good. Definitely a significant enough sound improvement over the old adapter. Will have to test and let you all know if the cutting out is gone. I hope so.
Best bet would be to order from the KZ store where I got this replacement from just to be sure you get the updated fixed adapter however for some reason the price has gone up and the current price of £34 would be hard to swallow. I paid £20 and felt like it could have been cheaper. Anyway
HERE is the link to where I got it from.
P.S. The new adapter box had a production stamp so maybe that is an indicator if you got the fixed version(?) Although it's under the flap you have to you tear away to open the box so no exterior indicator.
HERE is what it looks like. Everything else is the same.
