@archdawg which seller did you buy the new version kz zs6 ?
- Thread starter bhazard
archdawg
From the official KZ store on Aliexpress.@archdawg which seller did you buy the new version kz zs6 ?
Just keep in mind that they need some serious burn-in. I gave mine 100+ hours and noticed quite a change with my trusty test tracks.
voicemaster
Believe me, I'm trying to resist, too!
This ZS10 pro sounds so good.
voicemaster
raccoon city
I'm looking for KZ IEM's that are bass heavy, and about $15 or less.
Bonus points if the IEM's are nice and loud.
All I have are a pair of KZ ATE-S.
What do you recommend?
voicemaster
If you could up the budget to $20 then kz zsn is pretty good.I'm looking for KZ IEM's that are bass heavy, and about $15 or less.
Dobrescu George
Reviewer: AudiophileHeaven
KZ ZSN
mbwilson111
- Oct 13, 2016
KZ ZS3e
voicemaster
Problem with zs3 or zs3e is the shape of the iem might not suitable for everyone while zsn shape is pretty universal. I don't know about the sound of zs3e tho, but i do have zs3 and it was pretty nice, but it hurt my ear after awhile.
BadReligionPunk
Bass heavy is a subjective term and means different things for different people. I consider myself a extreme basshead. KZ ES4 are legit basshead. They also take EQ boost and Amp rather well and can go to a level that most cant. They should be around $12.
courierdriver
How ironic, as I'm going in the opposite direction, preferring iem's now over headphones. Had a bad experience many years ago with an iem and swore I'd never buy or like one ever again and then got into headphones. Over the past 6-8 months though (after discovering HBB aka BadGuyGoodReviews on YouTube) and buying the Moondrop Kanas Pro, I'm so impressed with how far iems have come both in sound quality and comfort that I'm seriously thinking about selling my headphones, as I rarely listen to them anymore. I have more of an issue with my ears getting hot and sweaty under the pads, than with iem's causing irritation inside my ears. Funny how everyone thinks differently at times.this review doesn't help
http://www.thephonograph.net/kz-zs10-pro-review/
but i won't order them, as much as i'd like to hear them. i already have several pairs of IEMs and they are getting less and less use over time. I prefer the sound of headphones for one thing. Even small headphones like the Koss KSC75's. And more importantly, I have sensitive skin in my ears which gets very itchy no matter what type of tip I use.
There's no doubt the the small form factor of IEM's is attractive when you are mobile, or exercising....but they just don't work for me any more.
Slater
I left you a message in the big ear thread. I’ll check those large tips for you on a bunch of KZs, and you can decide from there
Update: I verified those large tips you need work on the following:
ED9 (both filters)
ATE
ATR
ATE-S
ZSN
ZSN Pro
ZS10 Pro
ZS5
ZS6
ZS7
ZSR
CCA CA4
CCA C10
It does technically fit the EDR1, EDR2, ZS4, ZS3E, but not super tight and may theoretically come off in your ear. It may be OK though.
Slater
I enjoy both, but I totally understand your frustration with the headphone hot ear issue. I usually use headphone less (and IEMs more) in the summer, because it’s hot enough I don’t need to make myself even hotter.
It does help if you use an open headphone, especially one with velour pads. The Fidelio X2 or X2HR is a good option, but there’s a million.
Also, Brainwavz just came out with a new universal ear pad that has a layer of cooling gel to address this exact problem. So that may be an option for you, assuming it fits your headphones and doesn’t change the sound in a negative way.
Just giving you some options to consider...
courierdriver
Thanks for the info, Slater! I might check into those Brainwavz pads and see if there is something available for the cans I own. Only set of closed back I have is the Takstar Pro82, and funny enough, those I have the least problem with. The pads are super comfy and I can wear them for hours. My 2 open back (Grado SR225 and Massdrop Hifiman 4XX) are the ones that get the warmest for me. The foam pads on the Grado gets itchy fast and I have the new A-pads (I think that's what they call them) on the 4xx that have a velour part that sits against your head over your ear and the rest of the pad is like a pleather memory foam like material which I find gets really hot and uncomfortable after less than 30 minutes of wearing them.I enjoy both, but I totally understand your frustration with the headphone hot ear issue. I usually use headphone less (and IEMs more) in the summer, because it’s hot enough I don’t need to make myself even hotter.
