i got an unsolicited (and wholly unexpected) pair of kz zs7 from an ali seller and submit herewith my initial impressions (i'll post a fuller review on otto motor's site):
Soundwise, these are slightly warm, energetic and very spacious-sounding, with a rich note texture. Signature is balanced, in the (technical) sense of not unduly emphasizing a particular frequency, though by no means audiophile flat—there’s a certain adrenalized quality throughout the spectrum, though less so than the hyperfrenzied ZSN. Low end has good extension, depth and impact and shows much better control and speed than the bloomy ZS5 or ZSR, which tended to bleed over into the higher frequencies—midbass in particular has less quantity and focus than the ZS6, resulting in a cleaner presentation. Midrange (especially lower mids) sounds full and forward; guitars and male vocals in particular have a lot of body, albeit with a “chesty,” heavy quality on some material. As noted, treble is noticeably less extended here and these have little of the sharpness and shrillness of the ZS5/ZS6, although the ZS7 rolls off sooner and presents less information (they’re also less exhausting); there’s some sparkle but drums and cymbals lack just a little snap and realism. Soundstage isn’t as wide as the ZS5 or ZSR but nonetheless uncongested, enveloping and 3D; the effect is closer to open-air headphones. As with most KZs, imaging and instrument placement are excellent for this price class. While not seamless, driver coherence is much better on these than the ZS5 or ZSR; bass in particular is better-integrated and there are fewer audible peaks and dips.
Where these trail the pricey universals they’re aping is in the naturalness of the presentation and reproduction of low-level details like fingertips and reverberations--you remain conscious of hearing a reproduction of instruments rather than the actual instruments. Owing, I’d assume to the quality of the drivers used, the subtlest elements are somewhat repressed; compared to something the UE900s, these sound artificially juiced and slightly coarse. These differences may not be cost-effective if, like me, you typically listen to lossy files on less-than-optimal sources, and lots of times one prefers this less delicate presentation. In the same price range, the smaller-sounding Bosshifi B3 or BQEYZ BQ3 may sound more accurate, though the ZS7 is more fun and is a definite step-up from its predecessors. Recommended.
That said, going forward I'd like to see KZ change the formula and move, at least on some models, towards that amorphous higher resolution--as viscerally enjoyable as it is the ZS7 is nonetheless an enhancement of their party-hearty house sound, as opposed to a new tuning; broadly speaking there's not a ton of differentiation between the $50 ZS7 and the $15 ZSN. Maybe that's what they're doing with CCA, which I haven't heard (as an inappropriate aside, my beloved bride, a prolific artist, tends to paint the same face over and over again. she use different mediums and colors, and some are better than others, but it's still the same face). hire different engineers. embrace the unknown. have a good time.
