Huh, I just noticed one of the connectors of my ZS7 is wobbly to all sides, with the cable (tightly) connected. Anyone else have this problem? I wonder what happened.
That happens from time to time on some KZ 2-pin models. It is no cause for concern.
All KZ 2-pin models have molded notches that hold the female sockets in place. The IEM shell has notches that mechanically lock into notches in the 2-pin socket like a key. So there is absolutely
no risk of the jack falling in or out. The slight jack wiggle doesn’t hurt anything. It is strictly a cosmetic or perfectionist type thing.
Some members have added a bit of glue to the 2-pin female sockets to eliminate the wiggling. It makes them sleep a little better at night, but again is technically unnecessary.
Luckily it’s easy to do to models with removable backs such as the ZS6 or ZS7. If you do choose to do it, don’t use superglue. Take the back off and use a minimal amount of 2-part epoxy or glue like E8000. Don’t use too much or it could ooze out and obstruct the socket, or goop onto the pins possibly screwing up their ability to make proper contact.
Other disadvantages of adding your own glue is it making it harder to work on the jack if you ever needed to (like to turn it around or resolder it if it’s out of phase). In addition, the glue will make the rear cover much harder to remove in the future.
I personally leave my loose ones alone. It’s very minimal wiggle, and literally doesn’t hurt anything. Yet trying to eliminate the wiggle can do more harm than good.
Video showing the differences?
I will receive them this week and I want to know if that happens to mine as well.
No video needed friend. It’s just like if there’s an electrical socket in your wall that’s a little bit loose when you go to plug in a lamp or vacuum cleaner. The electrical socket still works perfectly and isn’t in any danger of falling out of the wall. It just has a mm of wiggle that’s all.
Don’t stress about stuff that may never happen friend. I don’t worry about being struck by lightning, or piano falling out of a window and landing on my head when I walk down the street, because those things may never happen. The loose sockets affect a small % of KZs, and even then it is no problem and hurts absolutely nothing. Too much stress and anxiety is bad for your health.
