PhonoPhi
Oh okay. I've just read that thread because I was wondering if my green ZS6, which sounds markedly different from the older red one, might have polarity problems. I still have no idea if polarity is the cause, but as for the concept, I get it...I think..?
My understanding:
There's actually a difference between phase and polarity.
Polarity is reversing the electrical signal, as when you switch or invert the + and - in a wire. As it is simply a reversal of the signal it would not be time or frequency dependent.
Phase is a result of changing a signal in time, and could be caused by reactive components in the signal path.
Simply reversing the polarity would not affect the phase; its graph or waveform would show a mirror image of the original signal along an axis. Shifting phase along the same axis is just like introducing a time delay; with the right amount of delay its waveform could be 180 degrees out of phase with the original waveform such that it would be identical to a reversal of polarity.
Hmm...tools of the audio engineer.
I thought all along they were one and the same; that is, if the internal wiring of my baffling green ZS6 were reversed, it would then be out of phase.
Anyway, I hope I understand it correctly. If not, well I'm open to anything just to ascertain that there's nothing wrong with the green ZS6 and that it's just tuned differently.
You definitely get it
Thinking simpler (for pragmatic purposes) - cables can be connected only two different ways, thus changing polarity (roughly equivalent of being in an opposite phase) is the only option to experiment with - and definitely worth to try to check if something is wrong.
In multidriver IEMd, some drivers can be possibly connected incorrectly, which would be harder to rectify.
