Thanks so much, Clear! Some questions, if you don't mind:
1) Do you also happen to have the ZS10 (also 1 DD + 4 BA)? If yes, how does the CCA C10 compare to it sound wise?
2) From your photos the CCA C10 looks gorgeous; how is it (shell + cable) in terms of build?
3) Apparently the ZSN cable (that seems to be that of the ZSN Purple) is thicker; from what you have researched, is there only 1 type cable for all 3 C10 models or is there any difference, like that with the ZSN purple vis-a-vis the cyan and black?
You don't have to answer right away. I'd rather have the answers to my first 2 queries after you've given the C10 some time to settle and after you've properly put it through its paces.
You've bought yours for only $28, right? I could get it here (Shopee) for ~$27.50 or even less with more Shopee Coins.
Right now I'm sending all sorts of positive vibes sprinkled with lots of hints my husband's way as regards the KZ AS06 and the CCA C10. Hope these will be received favorably and fruitfully by year's end.
