Nov 12, 2018 at 8:08 PM Post #37,907 of 67,793
Nov 12, 2018 at 8:49 PM Post #37,908 of 67,793
Here's the actual differences with the wires and nozzles for the purple/silver and cyan/black ZSN...
If you have both, you'll definitely hear the difference with both wires. It might not be night and day, but it was noticeable enough for me to hear that the dark wire makes the ZSN sound a bit thicker in the bass region and provide a warmer vocal tone to the MID region, while the lighter wire provides less in both areas giving it a better balance throughout the whole signature.
Hope this helps... -Clear
I'm assuming you switched the wires between both ear pieces to see the differences too and this is that calculation?
Nov 12, 2018 at 9:09 PM Post #37,909 of 67,793
Also, the phonograph have just reviewed the ZSN if anyone was interested in their take on it
Is it just me, or is that review whole lot of fluff and approximately 2 sentences of actual useful info?
He even says the ZSN cable is the same cable used on every KZ??
I know some people like that site, but that particular review seems like it was hastily thrown together.
On a positive note, the most useful thing I took away? The ZSN is basically identical to the ES4 according to the FR graph (except above 16k, which is beyond my hearing limit as well as being unreliable to measure).
Nov 12, 2018 at 9:12 PM Post #37,910 of 67,793
Does the ZSN and ES4 share the same DD?
Nov 12, 2018 at 9:36 PM Post #37,913 of 67,793
Slater mentioned it's like the ES4 which is not worth $99+ as the ED16 is much better.
Pretty sure No. Also neither of the iems sound remotely close to each other.
No no, I said they look identical up to 16k according to the FR graphs posted by thephonograph. I have never heard either in person, and FR graphs do not tell the whole story!
Nov 12, 2018 at 9:43 PM Post #37,914 of 67,793
No no, I said they look identical up to 16k according to the FR graphs posted by thephonograph. I have never heard either in person, and FR graphs do not tell the whole story!.
Yea that's interesting. Graphs are pretty much identical but both iems are completely different in sound and character
Nov 13, 2018 at 12:04 AM Post #37,916 of 67,793
+1 I saw many inconsistentcies, which I personally don't agree with myself. :spy:...that makes two of us!
Nov 13, 2018 at 12:22 AM Post #37,918 of 67,793
+1 I'm sure it should sound different. From what I'm seeing, 5,000hz and above fluctuates totally different from each other giving the edge to the ZSN from not dipping so low at the highest peak.
...Then again, I don't go by graphs alone as well. :smirk:
