These are my favorite “large” cases. As you mentioned, they aren’t as secure clasping or water proof (I don’t need water proof audio gear anyways). But they are a good balance of low cost with large size, and provide adequate protection. Plus the including foam lining is great for using on earphone mods (such as BA and nozzle mods).
That's true. These are even cheaper than the abs ones. If only they could just scale the abs variant to the dimensions of the larger one. I mostly use the smaller with normal in-ears, but with my customs it's very impractical, you need to really try to fit them in.
When trying to remove the clasp, they are very stiff, at a point where you are afraid of either breaking the clasp, or your nail. Also the clasps are held just by a thin plastic join, which is prone to breaking in the future. But for 1.5€, why care?Podster! Is that the Shan.M0?
Does it sound good?
ThanosD: I currently have that black case and fit my KZS5 & BA10 iems in it. My little plastic latch thingys are very
positive when latching giving a nice snap shut. New kinda how it is the latches are tight now but should loosen.
Water resistant maybe but submerging it might cause issues.
