Aug 11, 2018 at 7:46 AM Post #35,446 of 64,004
Save money and get zhiyin z5000.
But, lemme tell you
Try listening dubstep and electronic on mid centric iem. These music tends to sound large and hall like in neutral monitor which I enjoy a lot.
Mid-centric like? Tip me some budget iems maybe i know
Aug 11, 2018 at 8:11 AM Post #35,447 of 64,004
Still think the HDS1’s are the best tiny/small solution even easy to sleep in:wink: Next to ED9
Aug 11, 2018 at 10:58 AM Post #35,448 of 64,004
I don't like z5000. Really bassy. Have sub bass on mâle vocal :confused:
Aug 11, 2018 at 12:30 PM Post #35,449 of 64,004
It’s a shame they aren’t available anymore. My only pair of HDS1 died a long time ago :frowning2:
Aug 11, 2018 at 12:50 PM Post #35,450 of 64,004
I hope BA10 will bring down the price of AS10 (which I would like to try someday) cuz ~60$ price tag is way too near to B5+, IT01 and other 100$ goodies. KZ just haven`t proved reliability with their SQ/BQ/QC to just pay out 60$ "blindly".
I`m quite sure though, that AS10 SQ is very good if it would sell about 35-40$ max.
Personally I don`t like BA10 design a bit - looks uncomfy (especially for small ears) and it isn`t nice looking imho. ES4 / AS10 style is very good and kind of KZ house design which they should continue imo.
Aug 11, 2018 at 12:56 PM Post #35,451 of 64,004
Aug 11, 2018 at 1:59 PM Post #35,452 of 64,004
TinAudio T2, BGVP DS1, etymotic er4xr etc
Depends on the tip. Use cp240
But at the same, KZ as10 has upped its game in SQ if I compare to any KZ. Plus for 60$, it justifies
And KZ states that AS10 are all QC checked properly and are limited supply
Aug 11, 2018 at 5:56 PM Post #35,453 of 64,004
Aug 11, 2018 at 6:58 PM Post #35,454 of 64,004
Hi friends, I bought new kz Bluetooth. Its signal sensitivity very bad. Signal lost when I only put the phone into my back pocket.
So I disassembly to find Bluetooth antennae. I found chip antennae.
Any recommendation to upgrade antennae for best signal?
fk6
fk5
Aug 11, 2018 at 7:12 PM Post #35,455 of 64,004
The previous model of KZ Bluetooth had an antenna on the board. There was a design defect which caused poor reception, but the antenna could be extended to correct the issue.
I don't see an antenna anywhere on your (new model) board. I suspect it is in the "pod" on the other side (ie in the other "pod"). Or perhaps the actual wire between the "pods" is the antenna (the iPod 6G used the earphone wire as its FM antenna, for example).
Aug 11, 2018 at 9:33 PM Post #35,457 of 64,004
I assumed E labeled blue chip on the right side is chipped antennae. If I replaced with best reception antennae. It can be help?
No idea friend. I don’t have any experience with a ceramic chip antennas. You could try getting a better antenna chip and swapping it out?
Can you measure the length of that blue chip in millimeters, and let me know what it is?
I do know your experience with poor signal is also reported by other KZ cable owners. So it does appear to be some sort of design issue with the new cable (ie maybe with the antenna, ground plane, or perhaps shielding).
I know I am staying far away from the new KZ Bluetooth cable. Perhaps they will revise it and make improvements at a later date. Until then, the TRN cable is the best one to buy.
Aug 11, 2018 at 10:44 PM Post #35,458 of 64,004
Thank Slater I disassembly it because I was inspired by you lol. My friend suggested TRN too.
Length of blue chip is about 3.5*2mm
Aug 12, 2018 at 2:30 AM Post #35,459 of 64,004
If you look here, you will see a number of replacement antennas that will fit the KZ cable: https://www.mouser.com/Passive-Components/Antennas/_/N-8w0fa?P=1z0x01lZ1y93es5Z1yu8mv5Z1z0x0j9&Ns=Length|0
If it was me, I would swap the KZ antenna chip with any of the ones in that list (although I wouldn't recommend the 1.7dBi gain antenna). Also, the tallest chip in that list is 1.2mm, which looks like it will be fine judging from the photo you posted of the stock antenna chip.
The antenna chip will swap out easily with a soldering iron (or take it to a local electronics shop or phone repair shop and they will be able to do it for you in a few minutes).
I know that Mouser is not in your country, but the point is that you should be able to easily locate the same components listed on that Mouser page in your country (or import them).
If you do swap the antenna, be sure to let us know how it goes because it could help out others who are unhappy with the KZ cable performance!
Aug 12, 2018 at 6:15 AM Post #35,460 of 64,004
just got the KZ APTX bluetooth ... and cant seen to use APTX mode in developer mode... only AAC..... any solution?
